Lowering Springs And Sport Struts, Bump Stop Needed?
Started by TyConn, Dec 24 2011 01:36 AM
Posted 24 December 2011 - 01:36 AM
I'm trying to order a bunch of parts for my car on FCP, and i was wondering if i'm lowering the car, do i still need the bump stops, and how important are the dust boots. Do I NEED New bolts/nuts for the struts where they bolt to the wheel hub?
Probably stupid questions, but i just want to make sure before I order stuff I don't need
thanks for any help!
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT...RIP at 320K
1990 245 DL M47
Posted 25 December 2011 - 01:19 AM
I just did this job today. I got bilstein hd and ipd lowering all the way around. Also got new hardware for the front I would reccomend gettig new bolts and if you get everything you need for the front you can putit all in as one assembly. Not to mention not having to do it again when one of the old parts fail.
98 t5 auto :(, ipd exhaust, ipd cai, samco intercooler and radiator hoses, glowshift wb afr, boost, and oil temp gauges, hallman mbc @ 13psi, sconeman intake
Posted 25 December 2011 - 08:44 AM
The dust boot protects the shaft of the strut from dirt/dust/water. If dirt and other crap were to get past the seals of the strut it could damage it. I would replace the boot if its damaged or worn out. Here's the kicker, the boot is held up by the bump stop on the front struts, so if that fails your boot will fall down. I had that happen to be and it did force me to replace the bump stop as a result. So my lesson here, is do everything and do it right from the beginning
1998 Volvo S70 T5 Red AT - Stage Zero completed, ARD Orange Tune, ARD Lightweight Crank Pulley. iPd HD endlinks, CJ's Strut brace, iPd Anti-Sway bars, Bilstein TC struts, AC Delco TCV Valve, iPd stainless steel braided brake hoses, StylinMotors silicone vacuum hoses and intercooler hoses, SC-901 w/ Center channel and prologic processor, Planet Audio 400W 4ch Amp, Blitzsafe AUX in adapter, Homelink Visor, rear armrest cupholders, LED sidemarkers, rear mudflaps, and the list goes on and on...
2007 Volvo S80 V8 Silver - Stock.
Posted 25 December 2011 - 01:14 PM
yeah tyler, get bump stops and boots. spend the extra couple bucks.
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
