I went to a mechanic and I got several codes.. not too sure what to do. Any ideas if anyone has had similar issues? thanks.
1999 V70 Engine Idles Rough & Won't Accelerate? Any Ideas?
Started by ilygurlie, Dec 27 2011 04:55 AM
4 replies to this topic
Posted 27 December 2011 - 04:55 AM
Posted 27 December 2011 - 06:49 AM
Idea: get codes and post them here....
Seriously though, you can't diagnose this without real info. The codes are displayed to tell YOU what to look into fixing, not to play guessing games.
Posted 27 December 2011 - 07:23 AM
p1017 p1021 p1026 p1031
^ are the codes I received.. I spoke to another guy, and he suggested I clean the throttle or replace it?
Posted 28 December 2011 - 05:10 AM
Year/model/trim?
An accurate description of the symptoms you are experiencing would be of great help
98 S70 T5M
Posted 03 January 2012 - 01:14 AM
Is this you? http://www.justanswe...and-engine.html
I'm gonna go ahead and say with some confidence its not you're throttle/throttle body. But it does however sound VERY much like a mass airflow sensor problem.
It is likely NOT going to cost you 1500 or whatever that j/a quoted you. Unless of course you are taking it to a dealer.
I suggest getting some MAF cleaner and * carefully* cleaning it up. Also perhaps try removing it and starting the car- it will stall (possibly within a few seconds) but try and see if it runs any smoother, perhaps proving the maf is indeed the culprit.
This article shows a little info on the MAF
http://volvospeed.co...low_sensor.html
Its really easy to remove, just unhook your airfilter box, those clamps unscrew and you can pull it off the pipe... be careful no to touch, or let anything touch the element inside... also it may look clean but clean it anyway... its usually something you can't see that's messing it up.
Edit: Also finding some other info here on the codes you posted- highly reccomend googling them with the words "obd2" or "volvo obd2" as a prefix- yields some useful info-
http://www.matthewsv...php?f=1&t=20685
Could just a bad idle air control too- can clean that with carb cleaner or something similar. Def make sure its plugged in though.
Also- update your profile/sig with your cars year/model/etc and a location perhaps if you are a near another "enthusiastic" vs member they'd be happy to help you out in person.
Edited by pcguru000, 03 January 2012 - 01:28 AM.
