Mcleod Hydraulic Throwout Bearing Part Number
No replies to this topic
#1 Crazy Octopus
Crazy Octopus
  • 1 posts
Posted 28 December 2011 - 10:25 PM
I had a topic running on turbobricks, but seeing as it dead once again, I am going to ask here.
I am in the process of picking up a McLeod Hydraulic throwout bearing for the T5 transmission swap on a redblock b230, and am curious if any of you know the correct part number to pick up.
Originally i remember seeing someone somewhere post that you need to get the 13025, but as I can no longer find that anywhere on the internets I am starting to think that I was mistaken.
Here are some specs that may come in handy to help you help me.
Transmission - 1352-034 (Ford 1983 SVO Mustang 5.0 V8) -- I know what you are thinking an SVO v8 didnt exist but hey that is what the registry says, and if all goes for awesome it could be an old Ford Motorsports Transmission
Engine - 1995 B230 Redblock
Bellousing to Engine dimension - 5.5" (I haven't installed the flywheel/pressure plate/clutch yet)
Input shaft diameter - .668" (small portion that fits into the bearing) 1-1/16" 10 spline
Input shaft collar length - 3.5"
After measuring those I am starting to think that I need to get the 14005-30
Thanks in advance.
