Diy Rip Kit
Posted 30 December 2011 - 01:05 AM
My question is: What are the ODs for the inlet and outlet of the oem intercooler as well as the throttle body?
I did a quick search but came up empty handed :-/
I realize a RIP kit wont be much power wise but its a simply way to ditch the plastic pipes, rubber couplers, and add a bov.
Posted 30 December 2011 - 01:12 AM
Posted 30 December 2011 - 02:04 AM
Plastic is actually about the best material.
Volvospeed On Google+
Posted 30 December 2011 - 02:26 AM
Besides, while the rip kit wont really do much for power it should help throttle response which is a bit underwhelming as it stand right now.
Thanks for the quick reply btw. I take it all three ODs I asked for are the same 2.25"? That will make life easy.
Posted 30 December 2011 - 02:33 AM
From memory pretty sure. Do a before and after dyno and let us know how many HP you lose as well as what material and what routing.
Posted 30 December 2011 - 04:49 AM
Posted 30 December 2011 - 05:02 AM
Posted 30 December 2011 - 11:27 AM
Che, on 30 December 2011 - 02:33 AM, said:
cgally, on 30 December 2011 - 04:49 AM, said:
Posted 30 December 2011 - 02:02 PM
I wont be using 3" piping and the article doesnt list the oem TB OD. Personally I'd also prefer to use angled pipes instead of so many couplers but it looks like a good clean setup. Only missing the IAC pipe in his pics. I'm guessing this is our VS friend with the "ultra gutted" 854 from the looks of it.
Posted 30 December 2011 - 04:22 PM
Posted 30 December 2011 - 08:13 PM
I'll likely be sticking with the 15g as it's for the girlfriend. No need to go all out.
Posted 30 December 2011 - 08:20 PM
Posted 30 December 2011 - 10:04 PM
Top IC port: 2.5"
Throttle body: 2.5"
Bottom IC port: 2.25"
1996 Volvo 850 Platinum Edition"R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK,
#14
Posted 30 December 2011 - 10:43 PM
#15
Posted 31 December 2011 - 12:27 AM
Thanks for finding me the exact dimensions guys. I doubt I'm going to survive this 60% layoff so an fmic is going to be off the table, haha. The girlfriend will just be happy to make the engine bay a bit cleaner looking. At least I'll have a lot of time for wrenching ...
#16
Posted 31 December 2011 - 01:50 AM
Might as well spend the same on a cheap fmic kit then add the two reducers I'd need. :-/
I guess I'll just have to wait and see what happens with my job and if $$$ is fine I can just get an fmic kit.
Maybe this should be a sticky to dissuade others from traveling this path. Without the ability to weld aluminum (and therefor reduce the number of couplers needed) there's simply no way it would be of value -vs- a cheap fmic setup.
#17
Posted 31 December 2011 - 03:37 AM
#18
Posted 31 December 2011 - 05:14 AM
lookforjoe, on 31 December 2011 - 03:37 AM, said:
So, for everyone who's reading this thread - If you're thinking RIP kit ... "Just Say No" - Not worth the $$$ and if anyone's curious I'll post the cost breakdown of the required couplers to show how I got to $125. That's with cxracing prices which aren't even expensive vs better companies like stylin motors.
#19
Posted 31 December 2011 - 05:21 AM
'05 xc/90. The stereo sucks.
#20
Posted 02 January 2012 - 05:18 AM
