Looking For A Good Turbo Diagram And Parts Listing
Posted 30 December 2011 - 01:16 PM
Anyway, if anyone has or can provide such information, it would be much appreciated.
Thanks!
"Turbobricks don't accelerate, they gain momentum" - Cox Man
Posted 30 December 2011 - 03:52 PM
As for a diagram, it's a extremely basic set-up. I rod with bushings and a thrust washer. A diagram won't do much for ya.
Posted 30 December 2011 - 04:13 PM
Posted 30 December 2011 - 04:19 PM
Miles? PCV replaced?
Posted 30 December 2011 - 04:23 PM
Posted 30 December 2011 - 04:56 PM
Posted 30 December 2011 - 05:48 PM
Posted 30 December 2011 - 06:00 PM
When it comes to these vehicles, it's very rare to have the turbo fail. It's possible, but unlikly.
Also, timing belt? was that done at 70K? if not get on that!!!!
Posted 30 December 2011 - 09:23 PM
Someone else mentioned the smoking dipstick, I'll go check that here shortly before running to advance.
Also, unrelated, gas caps, seems replacement are Stant, can I get OEM, or even need OEM? (Many evap codes)
Posted 30 December 2011 - 09:34 PM
Posted 30 December 2011 - 11:29 PM
So, I went to Advance Auto, and they say it's not needed/they don't carry it. Wasted trip aside from ABC stop.
Is this a dealer only part?
Posted 30 December 2011 - 11:37 PM
Posted 30 December 2011 - 11:45 PM
Oh well, I'll check IPD and FCP.
Thanks for all your help PD!!
Okay, the only PCV valves I've delt with mount in the valve covers on V8's. Can you give me a link to exactly what I need to order please. IPD didn't have a PCV valve exactly.
Or verify the part is also called an oil trap.
Thanks!
#14
Posted 30 December 2011 - 11:49 PM
#15
Posted 03 January 2012 - 11:40 AM
#16
Posted 03 January 2012 - 11:16 PM
Replace ALL the breather components, don't cheap out. Also make sure you clean the ports in the block when you take it apart.
This is a breakout of the turbo lines
But, as PD pointed out, it most likely clogged breather. The oil drain tube gasket can leak, but that comes down, not onto or into the exhaust.
Valve stem seals are also very common, but they will typically only cause smoke on startup & then go away until the car sits again, unless they are VERY bad, at which point the oil can leak past the manifold gaskets & cook on the manifold, ask me how I know.
#17
Posted 06 January 2012 - 01:58 PM
What do you do to clean the ports (intake I'm guessing)?
#18
Posted 06 January 2012 - 04:21 PM
#19
Posted 06 January 2012 - 04:59 PM
http://www.ipdusa.co...ther-system-kit
http://www.fcpgroton...ther System Kit
#20
Posted 06 January 2012 - 05:07 PM
