I've got the unit all hooked up, but what do I need to fill the gaps?
Are there any kits around?
Jonathan
Double Din 2000 V70 Install Kit? Which One For Fh-P8000Bt
Started by stereophile33, Jan 02 2012 05:33 PM
4 replies to this topic
Posted 02 January 2012 - 05:33 PM
Posted 02 January 2012 - 08:19 PM
Make and model? If your DD didn't come with a factory trim plate in the box, check
with the manufactor and see if it's available. The factory trim, ( if you can get it ) will
have a perfect fit around the nose of the HU. That's usually the more challanging part
of the job. Then, if it needs it ( and it often does ) you just mod the outside to fit the dash.
Otherwise, you'll probably have to custom fab it from some ABS flat stock.
Posted 15 April 2012 - 11:40 PM
Should have came with trim pieces or check for a Metra double din kit for volvo.
