3Rd Row Seating
Posted 03 January 2012 - 03:42 PM
Posted 03 January 2012 - 03:43 PM
Posted 03 January 2012 - 06:51 PM
So i'm guessing the tails, rear seats etc.. will all swap over into basically any 94-00 wagon?
Posted 03 January 2012 - 07:19 PM
#5 Guest_luke_jones_*
Posted 03 January 2012 - 07:20 PM
Posted 04 January 2012 - 08:01 PM
Posted 04 January 2012 - 08:23 PM
Posted 04 January 2012 - 10:28 PM
laird, on 04 January 2012 - 08:01 PM, said:
+1 on this... the 70 series have gray belts and the 850 belts are black
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
#9 Guest_luke_jones_*
Posted 04 January 2012 - 10:43 PM
the commissar!, on 04 January 2012 - 08:23 PM, said:
Hrmm...then maybe it was just 99 or 00 that had the different tailgate release. The few v70/xc70's that I've ever looked at were all without the inside release, only having the lock/unlock pull up by the wiper, but no actual lever to open the hatch from the inside.
Posted 05 February 2012 - 01:04 AM
What's the easiest way to get the 3rd row seat latch out of the back of the second row seat? Do I just need the plastic piece in the photo or is there more to it? After reading a few threads, I believe the wagons come with most of the bits in the back of the seats, you just need to cut the carpet and install said plastic piece?
Also.. does anyone know that those two metal brackets bolted to the backs of the 2nd row seats are for?
Posted 05 February 2012 - 01:42 AM
The little plastic latch gets pushed up or down and then comes out.
Posted 05 February 2012 - 03:55 AM
http://www.ebay.ca/i...=item230ba848fd
Says the seatbelts from 96 and older are not compatible? My set is from a 98 XC70, just wondering if it will indeed fit 94-97 850s as well as 98-00 wagons?
Posted 05 February 2012 - 01:44 PM
#14
Posted 05 February 2012 - 03:25 PM
echase76, on 05 February 2012 - 01:44 PM, said:
Thank you!
#15
Posted 06 February 2012 - 11:45 PM
if you want to buy them pm me...
im taking out 3rd row all together
88 W126 560 SEL (The Family Jewel)
#16
#18
Posted 07 February 2012 - 11:43 PM
Swag Swag, on 07 February 2012 - 01:09 AM, said:
Yep. Got it out without issue. You just push it down and it pops out.
#19
Posted 08 February 2012 - 07:58 AM
#20
Posted 08 February 2012 - 06:28 PM
