Under heavy acceleration I get a short squeal coming from the front right side of the car. Also, the boost will drop off about 4 - 5 psi. I removed and inspected the entire cold side pipe and hoses. Re-assembled and still have this problem. I don't think it's belt related since it on happens at specific times.
How do I check the intercooler for a leak?
Or, do I just install my front mount and see if it solves the problem?
I really prefer to get a drop in intercooler and sell my front mount kit but timing may force me to use it.
Strange Squeal And Boost Pressure Loss
Started by s60wot, Jan 05 2012 12:33 PM
6 replies to this topic
Posted 05 January 2012 - 12:33 PM
2001 S60 T5 - 18T - Vibrant FMIC - Full 3" straight no muffler dual Magnaflow resonators - BSR Stage III PPC - Green Injectors - K&N panel - Snabb intake - AEM Uego controller - silicone vac lines - QBM Mounts - 17" Falken RT-7M wheels - Elevate front sway w/ TKI HD endlinks - IPD rear sway w/ HD links - Blackout Eggcrate grill - painted eyebrow tails - M Rear Lip spoiler - Koni/Eibach FSD's - R Manifold - Sharp HIDs - 3M Di-Noc CF console[/center]
Posted 05 January 2012 - 01:45 PM
Since there is always some oil residue in the stock system, you should see evidence of particle spray if the leak is from the IC or piping.
How old is the serpentine belt & the tensioner? - This would have nothing to do with boost pressure loss - but maybe you have two issues going on...
Posted 05 January 2012 - 02:00 PM
I would get one issue fixed before installing something else which could create another issue and you have to track down 2 different problems.
Reguards,Scott. ~2005 S60 2.5T AWD: lil of this, lil of that, it goes pretty good now.
1/8 mi - e.t. 9.176 @ 79.24 mph, r.t. .569, 60' 2.129
Posted 05 January 2012 - 04:00 PM
I am going to throw this out there just as a thought. Could the turbo bearings be worn and the impeller is making contact with the housing wall? The contact would slow the turbine speed down, make a squealing noise and drop boost pressure. Just a thought.
13.7 @ 99 Automagic
13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
Posted 05 January 2012 - 04:07 PM
all belts and tensioners are good
turbo has less than 2k on it (Spanky built 18T)
boost fades even when niose isn't present at 10 psi
Posted 06 January 2012 - 04:42 AM
Small leak in intercooler? Or somewhere else on hotside.
I had suspected my intercooler leaked on my 854. My radiator needed replacing and I get massive heatsoak in Fl summers so I decided to do the frontmount while doing the radiator. It's not a difficult job to do the fmic.
2005 S60R 6M OBX full turbo back exhaust, titanium grey pearl/atacama sport package. Sold 94 854 T5. ST 17psi tune,IPD Hd TCV, Delco TCV, FMIC w 2 1/2 " piping, 17" Tethys, RIP 2003 3.2 CL type S 6spd
Posted 06 January 2012 - 12:30 PM
FMIC on S60 FWD is not so easy.
