98 Volvo V70 Xc Awd Engine Swap?
Posted 06 January 2012 - 03:04 AM
I am a long time honda fan, and love the ability to swap engines between cars and years with ease. I have been interested in volvo's for a couple of years now, I finally bought one for my wife. a 98 v70 xc awd. I love the car, but I'm looking for more power, I fear the engine is tired and changing the turbo/injectors/ecu would just blow the motor.
My question is can I swap a motor in from another v70/s70 or s60r with ease
If so what are my options from mild to wild
Thanks for your advice
Posted 06 January 2012 - 04:49 AM
1997 854 GLT NA Manual 192K - son; 1995 854 NA Auto 240K - daughter
Posted 06 January 2012 - 02:36 PM
Posted 06 January 2012 - 03:25 PM
You can also send your current ECU to any of a number of tuners to convert it to a stock HPT ECU or put whatever tune you want converted for the HPT ECU. '98 ECUs aren't mated to a car's vin # so you have lots of options.
The engine has nothing to do with the AWD so you don't have to worry about using an R motor vs. a T5 motor since I assume you are keeping your current AWD transmission which will bolt up just fine.
Me: "Yea."
Posted 08 January 2012 - 05:27 AM
Posted 08 January 2012 - 05:58 AM
wizzard_al, on 06 January 2012 - 04:49 AM, said:
Completely irrelevant information. If you want to run a VVT motor... dual or single... you do not need to do anything more than leave the VVT unplugged.
Example... I have a 98 V70R with an 07 2.5T dual VVT motor in it. Left unplugged.
the 01+ turbo motors are the way to go. There are some modifications to make them fit, but it truly is pretty much an easy swap. You need a front engine mount from a 99-00 motor, modify the timing cover to accept the older serp tensioner, modify the cam shaft ends to accept older accessories such as cap/rotor.
All in all... it's worth it to source a newer motor if you can afford it. Many advancements made in the 01+ motors.
1991 244 NA - M47
Posted 11 January 2012 - 03:30 PM
Good to know I just found a 99 s70 for sale this morning hpt so I could use the whole motor with the same mod's?
Posted 11 January 2012 - 04:51 PM
you wont be able to use the ecu from the 99 as its tied to that specific vin< might be wrong but its what ive been told. also ME7
Posted 11 January 2012 - 05:01 PM
He's talking about swapping this motor into a 98' ETM issues aren't relevant since to do the swap you would need to swap the intake manifold and tb from the 98' motor on to the 99+. Along with the other mods that need to be done that Korruption touched on. You'll want to get a T5 ecu from a 98, to go along with the injectors and turbo that the 99' hpt motor has.
Edited by jnderr, 11 January 2012 - 05:02 PM.
00' V70 NA 15XK Miles
84' 242 shell at the moment
Posted 11 January 2012 - 05:10 PM
Posted 13 January 2012 - 09:02 PM
Whats the mileage on the current motor you have? These motors can handle bolt ons pretty well...
Posted 14 January 2012 - 08:10 PM
Assuming this car was cared for before you, it shouldnt need a new engine for bolt ons. These engines are known to last way longer, 153,000 miles is nothing really. My cars at well over 280,000 miles (450,000 kms) and still going fine without any hesitation.
What i would do is go for a complete Stage 0, check all hoses, connections etc and swap the turbo and ECU to have a fun daily driver.
#14
Posted 14 January 2012 - 09:18 PM
Rocking the Tethy's now!
#15
Posted 15 January 2012 - 12:23 AM
Do what they said, bring it up to stage 0 and it should accept modifications nicely.
#16
Posted 15 January 2012 - 05:37 PM
Boost control valve? do you mean the valve above the rad connecting vac from intake to actuator?
Looks like if the engine is strong and healthy, I need high pressure turbo injectors and the correct ecu
#17
Posted 15 January 2012 - 07:33 PM
You have the LPT motor, it has a higher C/R than the T5 series (9:1 vs 8.5:1)
A basic "T5" upgrade (T5 turbo and ECU) will make a huge difference from the stock 190 hp you have right now.
If you wanna go crazy and maximize the potential of these upgrades, read around to see what you can do with a stock motor.
#18
Posted 16 January 2012 - 03:42 AM
#19
Posted 16 January 2012 - 07:50 AM
#20
Posted 16 January 2012 - 08:19 AM
If you put a 96 Motronic 4.3 ECU into a 98 Motronic 4.4 car your going backwards in ECU advancement. Your ECU can be more fine tuned then the older 4.3 ECUs. even though your car will run the old ECU id just get a tune, then you'll really like the XC
