Multiple Misfires At Wot
Posted 06 January 2012 - 05:17 AM
Problem:
Cels:
P0300
P0301
P0302
P0303
P0304
All cylinder misfires with the exception of the 00, its a multiple misfire .
What I have done:
Change the plugs to OEM Volvo gapped at .026
Replaced the Cap - Bosch
Replaced the rotor - Bosch
Swapped out the MSD Blaster with the OEM coil then back again
Replaced the wires from IPD to OEM then back to IPD
Added a MSD6a then gapped the plugs to .030
ARD blue tune to IPD then back to ARD.
Improvements:
IPD wires typically only threw the P0301 error and one time the P0303.
In general, the car starts and runs fantastic. You would never know there is a problem until you really go.
From the coil to the plug has been replaced or changed out for testing. It must be something else. Could it be the flywheel sensor or cam sensor? This is a problem that has developed over time. It has not always been there. The car used to haul butt. Something is amiss.
13.7 @ 99 Automagic
13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
Posted 06 January 2012 - 12:25 PM
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT/MegaSquirt 3X - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
Posted 06 January 2012 - 12:51 PM
Posted 06 January 2012 - 01:11 PM
This was non volvo, but one of our GM trucks would throw those same codes anytime there was heavy throttle (towing on highway etc..) and after going through all of the same ignition trouble shooting (plugs, coil packs in our case) it turned out to be crap in the injectors/fuel rail..cleaned all injectors and the fuel rails. (we actually had to clean the tanks too, but that's poor GM design in our case)
Edited by scumcity14, 06 January 2012 - 01:12 PM.
'05 xc/90. The stereo sucks.
Posted 06 January 2012 - 02:07 PM
Wouldnt I see a lean out on the AFR's?
I need to add that every once in awhile I feel a miss at idle. I have looked at the AFR meter and I go rich for that moment. That would indicate it was a spark loss.
13.7 @ 99 Automagic
13.8 @ 104 Manual
Posted 06 January 2012 - 02:17 PM
Posted 06 January 2012 - 02:32 PM
Posted 06 January 2012 - 04:19 PM
Gideon35T, on 06 January 2012 - 02:32 PM, said:
Nah, ongoing. Many, many tanks
13.7 @ 99 Automagic
13.8 @ 104 Manual
Posted 06 January 2012 - 04:43 PM
Posted 06 January 2012 - 05:33 PM
Also disconnect ther MSD 6A , run just the coil and see what happens there.
I guess mised that you tried another ECU already
Posted 06 January 2012 - 05:35 PM
ECU - Yes, tried my IPD and ARD
Plugs - BKR7Es where in there before I moved to OEM
MSD6a was added hoping to address the problem, I thought it was blowout (frowned on term but you know what I mean)
13.7 @ 99 Automagic
13.8 @ 104 Manual
Posted 06 January 2012 - 06:15 PM
http://www.vpcuk.org...ighlight=bloody
I've changed to a new bcs from ipd,
evap canister purge valve (which threw a cel),
bosch fuel filter,
bosch cap/rotor,
bougicord wires,
oem volvo plugs gapped at .028, better when they were incorrectly gapped to .025.
new crank sensor,
ONLY 93 octane from "top tier" companies
MSD coil from ipd
I threw in injector cleaner a long time ago.
I feel it is a fuel issue so a new fpr is what i'll do next, knock sensor upgrade kit costs ~$300 (same $ as the oem ones from teh stealer) might as well upgrade.
Idle is a steady 900rpm.
1997 850 T5..ARD Green/K&N Panel/IPD Parts/MSD/Silicone Everything
156MPH Sleeper...
Posted 06 January 2012 - 06:22 PM
Noob question, how do you clean the injectors and fuel rails manually??
156MPH Sleeper...
#14
Posted 06 January 2012 - 07:17 PM
13.7 @ 99 Automagic
13.8 @ 104 Manual
#15
Posted 06 January 2012 - 07:41 PM
Dr.PorkenheimersBonerJuice: no you didnt kev, you jacked it to pictures of teen mom. that isnt cougar
SHIT IM SELLIN ; SHIT YOU BUYIN. DONT BE A BITCH ; CLICK IT
#16
Posted 06 January 2012 - 08:48 PM
Ash Filler, on 06 January 2012 - 07:41 PM, said:
I would just check to make sure that the securing bolts are still tight as with a lot of vibration i can see them working their way out because I am pretty sure no one has ever lok-tite'd these bolts
A couple have recommended that and I will check and make an effort to move them regardless.
I have a second flywheel sensor and cam sensor...I could swap them both out???
13.7 @ 99 Automagic
13.8 @ 104 Manual
#17
Posted 06 January 2012 - 09:17 PM
#18
Posted 06 January 2012 - 10:46 PM
#19
Posted 06 January 2012 - 11:40 PM
broken041, on 06 January 2012 - 10:46 PM, said:
Its a 95 w/egr...no pump. You had my attention though. Your description is excellent.
13.7 @ 99 Automagic
13.8 @ 104 Manual
#20
Posted 07 January 2012 - 12:27 AM
