Turbo Tuner - How's It Working For You Guys?
Posted 07 January 2012 - 10:51 PM
Even though I have the disable emissions box checked, I am still getting a check engine light when running no cat.
When adjusting idle, I can seem to go leaner than 14.3 to 1 on the wide band, when I try to with the injector calibration wizard, the car just compensates and goes back to around 14.3.
Been waiting on a green injector tune from Turbo Tuner to see if it will be any different.
Anyone else having these problems? Or other problems?
www.petestacticalknives.com/vito.htm
To the UR underdrive pulley www.petestacticalknives.com/volvo.htm
www.petestacticalknives.com/jade.htm
Posted 07 January 2012 - 11:04 PM
Posted 08 January 2012 - 02:37 AM
What is your setup? What injectors are you using?
Normally, you just run the car until it's warm, make sure you've chacked & cleared any codes, then run the calibration wizard to get the AFR's @ 14.7-15.2, making sure to allow at least 10-15sec between adjustments for the AFR's to settle. This has worked for me for 4 different sets of injectors, as I progressively upped the system.
I have heard others using non-Bosch injectors successfully with ME4.3, but ME4.4 won't ever idle right without Bosch injectors installed.
Posted 08 January 2012 - 03:47 AM
Boost Addicted, on 07 January 2012 - 10:51 PM, said:
What code is set when the CEL comes on? Did you remove the rear O2 sensor also? I'm not running a cat either, but if I tried running without the rear O2 connected I would still get a CEL. I think the code was for the heater circuit.
Did this start when you installed TT or did it read 14.3 with a different ecu? Curious what wideband you have? I have the Innovate LC-1 and it has always read about 14.2. I've used it with a Speed Tuning ecu, with TT, and most recently with an ARD tune. I even had it installed on another vehicle before I put it on the S70 and it read 14.2 at idle and cruise. Tried another sensor also and no change.
So It's not really something I worry about. I'm just hesitant to run a REAL aggressive tune with TT, just in case my wideband isn't accurate. I keep it a little on the rich side (about 12) just in case it is off.
I've been happy with TT. Having the ability to log data is helpful, but not absolutely necessary. If you don't log data, it's nice to have someone with you to keep an eye on the boost gauge and wideband when you're tuning.
Posted 08 January 2012 - 05:56 AM
Posted 09 January 2012 - 05:06 PM
Literally, it straight up won't go on. LOL
Posted 09 January 2012 - 05:49 PM
1995 854 T5M Click for Mods
2005 S60 2.5 T
2010 XC60 T6 AWD
Posted 09 January 2012 - 05:51 PM
ErikS, on 09 January 2012 - 05:49 PM, said:
Talk to Adam, he will have you recover it. TTDIAG
Posted 15 January 2012 - 09:16 PM
President & Founder, Oregon Volvo Tuners
覧覧覧覧覧覧覧覧覧覧覧覧覧
'98 V70R AWD, '89 245DL, '71 142e, '67 122s
Posted 16 January 2012 - 12:31 AM
Edited by dublin14, 20 January 2012 - 01:23 PM.
Posted 16 January 2012 - 07:20 AM
Posted 20 January 2012 - 05:50 AM
