Modifying My Td04Hl-16T To Be An 18T
Posted 09 January 2012 - 05:24 AM
http://www.ebay.com/...=item58916e337b
Upsolute ECU, Samco intercooler/Radiator hoses, 98% Stage 0, Koni FSD, Eibach Pro-kit, IPD sway bars, IPD HD endlinks, SPEC Stage 1 clutch, QBM shift kit
Volans, Falken Azenis RT-615
Posted 09 January 2012 - 06:07 AM
Posted 09 January 2012 - 06:24 AM
Posted 09 January 2012 - 08:18 AM
Jardim, on 09 January 2012 - 06:24 AM, said:
will the super 6y0 wheel fit directly into the 16t housing or do you still have to get it milled. a place by me quoted me to turn my 15g to an 18t being that i suplied the wheel was 350$ you can get an 18t wheel on ebay for 55$ shipped. the quote for 350 was to do a complete rebuild, mill the housing and VSR balance. not to bad of a deal i think 400 for the entire conversion.
Super 60*
Posted 09 January 2012 - 08:46 AM
-Kevin-
04' Subaru WRX Wagon
:( 96' White 854, 19t, Quaife M56H, Turbo tuner :(
Posted 09 January 2012 - 02:34 PM
Posted 09 January 2012 - 05:43 PM
Vent pods: http://bprayventpods.webs.com/
Posted 09 January 2012 - 05:50 PM
You will need to get the assembly balanced, though.
This 19T kit is under 200
This 19T housing & wheel is under $140
Just be careful with boost control, that's all.
Posted 09 January 2012 - 06:06 PM
After I have mine done in the next week or so, I'll post back and let you guys know how it goes.
OP, if you need an angle exhaust housing feel free to PM me, I have a spare I can sell.
Posted 11 January 2012 - 12:21 PM
Off topic but just saw on your sig that you got a 13.99 with a 16t.
Edited by dublin14, 11 January 2012 - 12:22 PM.
Posted 11 January 2012 - 04:41 PM
Posted 11 January 2012 - 05:53 PM
El, on 11 January 2012 - 04:41 PM, said:
The difference there is that g series use one style thrust assy, T series use another. One is "superback" the other is "flatback", I forget offhand which is which, but as long as you bought the complete kit with seals, bearings & thrust assy, then yes.
Posted 12 January 2012 - 08:32 AM
I have built 19T from a good shape 13G.
Thread & Pic's: http://forums.turbob...ad.php?t=180675
Old: '87 740 turbo, 5cyl 2.0R, 19T, 3" exh, Sachs Race PP, M90, G80, Vems http://forums.turbob...ber.php?u=11795
#14
Posted 12 January 2012 - 04:07 PM
#15
Posted 12 January 2012 - 04:46 PM
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT...RIP at 320K
1990 245 DL M47
#16
Posted 12 January 2012 - 07:44 PM
#17
Posted 13 January 2012 - 08:26 AM
bpray9223, on 12 January 2012 - 04:07 PM, said:
Karnasch grinding bits,
Similar like this, but in "dremel" size:
then simple sandpaper 500, 800 finish
#18
Posted 13 January 2012 - 04:09 PM
My 20g impeller is TD05 in a 10cm2 housing - but the compressor was TD06 - until I increased it further with a Garrett 60-1 wheel & housing, which also required machining the CHRA for the wheel to clear the seat area.
Not surprising you raised your spool/boost onset time, with the porting you did. Did fixing the wastegate help, though? Having the arm drop out the housing meant that your wastegate flapper was not closing - that alone would raise boost onset rpm's.
#19
Posted 15 January 2012 - 09:16 PM
Spool up time of course rised compared to the stock smaller TD04H -13C. It is a different world in RWD.. (don't forget... 4bunger & tune was for "stock" turbo)
Turbine ported/opened to (had to) match with '90+ newer style exh.collector which has been machined as well. (http://i238.photobuc...09/CIMG6370.jpg)
It is a gain compared to the stock opening if you know how looks, it's a common upgrade on TurboBricks world, with good feedbacks.
I not remember now how was act afterward,
Wastegate drop caused zero boost under every RPM conditions on that setup...
I had the same! turbo on 5cyl 740 and spools faster, earlier than B230FT, no problem here. (Pm me if you need more details.)
