Bought My First Xc70, Need Some Help
12 replies to this topic
#1 cbpldc
cbpldc
  • 69 posts
Posted 13 January 2012 - 03:12 PM
Hey guys,
I've posted a few times in the older FWD section, but this is my first foray into this segment. I purchased my first XC70. Its a 99 with 175k miles on it and is that beautiful dark green color. The paint and body is fabulous and the interior is super clean. It is not without fault however.
It has a severe exhaust leak where the down pipe has come apart where the clamp holds the flanged end to the turbo. I've been searching for a down pipe and the best I could find was an OEM part for $580! Could someone point me in the right direction here? I wouldn't mind an aftermarket DP or even entire exhaust if it could be purchased cheaper. I also have the dreaded ETS light, and I've been researching that. My first order of business will be to take it to the dealer to see if its had its software updated.
It has a check engine light on for 02 sensor, but the huge gaping hole in the exhaust may actually be causing those issues. If not, I can fix that. I think will be due for a trans fluid change as once it gets warm, it shifts harshly into over drive, or when the torque convertor locks and unlocks.
Overall, I'm quite happy with the car, and its very capable, as I bought it and drove it home in the blizzard last night from Cincy to Cleveland (with my wife following in our Malibu) and had zero issues.
Thanks for the help!
Chris
96 850R (rescued from the junkyard)
94 940 Wagon
99 V70XC
#2 NEU
NEU
    Old Man Crew Photographer
  • 2,982 posts
Posted 13 January 2012 - 03:53 PM
You either get one custom made or you can get one from EST http://www.eurosport...=VL-S70-exhaust Or CJ Yonther, but they are both are pricey if you are baulking at $500+. But to be honest I'd just look for a used one from any '99-00 AWD, if you just need a replacement...
NEUBAR
#3 cbpldc
cbpldc
  • 69 posts
Posted 13 January 2012 - 07:22 PM
I do just need a replacement from a yard. Any good sources? Its pretty dry here in Cleveland for this kind of stuff?
94 940 Wagon
99 V70XC
#4 NEU
NEU
  • 2,982 posts
Posted 13 January 2012 - 07:29 PM
Place a "want ad" here...
NEUBAR
#5 cbpldc
cbpldc
  • 69 posts
Posted 13 January 2012 - 08:59 PM
Gracias
94 940 Wagon
99 V70XC
#6 db130
db130
  • 724 posts
Posted 13 January 2012 - 09:04 PM
i'd also check the build date on the label of the ETS/ETM - with the build date you can sort of guess how old it is
ex. 03W131503 - made in the 13th week of 2003
pretty sure all yellow label ones received the updated software
2000 V70XC SE, 149k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
#7 cbpldc
cbpldc
  • 69 posts
Posted 17 January 2012 - 01:44 PM
Update. On my way to my friends house about 2 miles from my destination, my temp gauge dropped, but it still ran fine. When I pulled into the garage bay and popped the hood, I noticed the dipstick pushed out and oil everywhere. When I pulled the dipstick out, it was like chocolate milk. So, I guess I popped the headgasket. I re-welded my downpipe though so when it goes back together with the new HG, at least it will be quiet.
Chris
94 940 Wagon
99 V70XC
#8 Keaton85
Keaton85
  • 6,439 posts
Posted 17 January 2012 - 02:23 PM
Chill out for a second and rethink this....
Headgasket maybe but here is another idea that's more realistic:
It's cold, the PCV system is shot and you need a thermostat since yours is stuck open. All that combined would fit the bill, but that's just assuming those items are bad.
First up, would be a compression check!!!
#9 cbpldc
cbpldc
  • 69 posts
Posted 18 January 2012 - 12:09 AM
Yeah, I will do that for sure. But the fact that I can see coolant leaking from the back of the head is a pretty good indicator. Also, the oil level is way, way high and looks like a milkshake. Are you saying that could be symptoms of something other than a BHG?
Chris
94 940 Wagon
99 V70XC
#10 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 18 January 2012 - 03:38 AM
Yikes, coolant leaking from the back of the head is not a good sign. The cheapest and easiest way to check for a blown HG is to remove the coolant reservoir cap and watch for something that looks like ol' faithful.
If you're still unsure you can verify with a combustion leak checker like this:
http://www.amazon.co...r/dp/B000NPDL76
98 S70 T5M
#11 cbpldc
cbpldc
  • 69 posts
Posted 18 January 2012 - 10:13 PM
Also found low compression in the No. 4 cylinder. Currently replacing the PCV system, timing belt, water pump and pulleys, and the ETM while I'm in there.
94 940 Wagon
99 V70XC
#12 Ghost Shadow
Ghost Shadow
  • 3,141 posts
  • Interests:testing
Posted 19 January 2012 - 02:06 AM
could be a broken headbolt between cylinders 3 and 4, it was that in my case. vvt hubs are tricky to get off. besides the stuff you listed, and if you are planning to keep this car, change out the upper and lower radiator hoses, heater hoses too, heater core, flush the intercooler out, you have work cut out for you.
there is a link to my project v70t5m so you get a idea of waht is involved.
good luck.
You want Volvospeed stickers?--->http://tinyurl.com/7axjudr
#13 cbpldc
cbpldc
  • 69 posts
Posted 19 January 2012 - 03:10 AM
Yep, I've got a heater core to go in it too. I found the intercooler hoses are crap, so they're getting replaced as well.
Chris
94 940 Wagon
99 V70XC
