What Can I Squirt On The Spark Plugs ?
10 replies to this topic
#1 KKM
KKM
  • 49 posts
Posted 14 January 2012 - 03:00 AM
I don't have any ant-seize, so can I use something like WD40 or motor oil to loosen?
'93 850 GLT 5-sp
201,000 miles
Still original PCV
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 14 January 2012 - 03:01 AM
installing or removing?
#3 KKM
KKM
  • 49 posts
Posted 14 January 2012 - 03:16 AM
I'm going to be removing my wifes 10 year old Camry car with 100k. The plugs have never been changed so I'm a little afraid that they will not be easy to remove. I've read where it's possible to break the spark plugs if it's seized due to too much force, if that happens, I'm on the couch for the next week. Please help your fellow weekend mechanic avoid the couch.
'93 850 GLT 5-sp
201,000 miles
Still original PCV
#4 Keaton85
Keaton85
  • 6,439 posts
Posted 14 January 2012 - 03:21 AM
PB blaster if your worried. Spray and let it sit overnight, then try to loosen them, then respray and work the plug back in and out.
Also having the motor nice and hot helps...
#5 831t5r
831t5r
  • 375 posts
Posted 14 January 2012 - 04:35 AM
Arocroil, how ever u spell it, in a orange can breaks loose anything.
95 850 T5-R - Sold : (
'00 V70R-STOCK/ ARD lightened Crank Pulley
'01 C70 Coupe - Stock
#6 BlackBrick
BlackBrick
  • 446 posts
Posted 14 January 2012 - 02:38 PM
make sure to put anti-seize on the new plugs so you never have to worry about this again.
and i didn't know this was a Toyota forum! :wacko:
#7 KKM
KKM
  • 49 posts
Posted 14 January 2012 - 05:26 PM
I looked it up and it is called Kano Aerokroil, claims to penetrate one millionth of an inch, will look for some, thanks for the suggestion.
I plan on putting some lubricant on the new plugs, thanks for the suggestion. I know folks on this forum are very knowlegeable about any questions car related so I ask here and hoping someone else will benefit from the answers.
'93 850 GLT 5-sp
201,000 miles
Still original PCV
#8 831t5r
831t5r
  • 375 posts
Posted 14 January 2012 - 06:19 PM
Ya aerokroil lol, i use it everytime i time i touch exhaust parts, breaks manifold bolts with no strength at all and no frozen bolts. Then again in cali we dont gotta really deal with those issues
#9 BlackBrick
BlackBrick
  • 446 posts
Posted 15 January 2012 - 01:43 AM
lubricant will not last. anti-seize compound will.
#10 James A Sousa
James A Sousa
  • 307 posts
Posted 15 January 2012 - 07:25 PM
You should remove the plugs every year or so and put a tiny amount of anti seize on them.
On Click and Clack (PBS radio) they advise - If you leave the plugs in for 100k, they will NEVER come out!
#11 Keaton85
Keaton85
  • 6,439 posts
Posted 15 January 2012 - 07:40 PM
Then I would have a lot of bad heads on volvos!
They will come out... also remove them every year? if you put antiseize on first then you shouldnt have to touch them until you replace the plugs again. Just wasting your time.
