Cannot Decide Between An 18T And K24 (Stock Bottom End)
Posted 14 January 2012 - 04:51 AM
I would REALLY like having the larger turbo that I can make 300ish WHP , without it being maxed out and blowing hot air. I can get a k24 with low mileage for under $500 so cost is pretty equal. Also I'm figuring the larger exhaust side should slow the spool time down making it a little safer, but some have said it spools even faster? So I have a couple questions for people that have installed a K24 on their non RN stock bottom end engines.
(Setup would be same as what's in my sig only new turbo, ARD tune, MBC in parallel to protect against spikes, wideband, and probably a FMIC.)
1.Has anybody here actually bent their stock rods with a k24? I've seen lots of speculation but I can't find a post from anyone saying it's happened to them.
2. What parts exactly are needed to install a k24? I know new oil and coolant lines, but are the s60r parts a direct bolt in? Does anything need to be custom made?
3. Is a k24 on a stock-bottom ended daily driver even a reasonable idea?
Sorry if i'm beating a dead horse here, I'm just really having trouble deciding and I dont want to pull the trigger if it's a bad idea.
Thanks!
-Casey
Posted 14 January 2012 - 05:46 AM
Posted 14 January 2012 - 01:08 PM
And on ANY Volvo turbo, just wait till the car gets to 3K before slamin them when chipped. Loading up a chipped stock motor at 2500rpm - max boost is never really a great idea. Also, its always better to stay on top of the turbo... as in rollin the pwr in vs just slamin it. I use that more than anywhere on the track especially.
Edited by dublin14, 15 January 2012 - 05:42 PM.
Posted 14 January 2012 - 01:29 PM
1995 850 T5-R yellow- EST Cold Air Intake - EST 3" Down Pipe-EST Exhaust - EST Strut-Sconeman Intake Pipe-ipd Sways F+B - Koni HDs with ipd 1.75" springs + ipd HD endlinks - Samco Turbo and Intercooler Hoses - RICA Tune - 18"anthracite pegs-ECode w/10K HIDS - Autometer Cobalt AFR,Boost, Oil pres Gauges
2006 XC90 2.5T-[i]black on black-Premium-DVD
Posted 14 January 2012 - 01:40 PM
1/8 mi - e.t. 9.176 @ 79.24 mph, r.t. .569, 60' 2.129
Posted 14 January 2012 - 04:33 PM
18T is just a glorified 16T and hardly at that.
Posted 14 January 2012 - 05:58 PM
I've been running a 19T for a little over two years now, stock bottom end. I was using an iPd tune, but switched to Lucky's tune. AFR's are great, boost response is perfect, and no issues thus far.
-1996 850 Turbo
-2007 XC90 V8
Posted 14 January 2012 - 06:19 PM
So what do I need as far as plumbing?
Also, are stock white injectors sufficient? Lucky says they are but I just want as much input as possible.
Cuz If I need to pick up a set of jolly green giants that's kind of a deal breaker.
Edited by 98t5M, 14 January 2012 - 07:53 PM.
Posted 14 January 2012 - 08:08 PM
Chris / 96 850 R-M / 98 S70 GLT -T5
Posted 14 January 2012 - 09:07 PM
I'll have a set of greens available with less than 15000 miles on them. Just pm me if you're interested
1996 Volvo 850 Platinum Edition"R" Exhaust Manifold, Garrett Stage III 54 Trim T3/T4 Hybrid Turbo, 550cc @ 3bar Injectors, Racelab Intake Manifold, 3" Full SS Exhaust, TurboTuner, CAI, BOV, Custom FMIC Setup, Crane Ignition, 5spd Swap, Walbro Fuel Pump, KONI FSD & Eibach Springs, IPD Sway Bar Kit, IPD BBK,
Posted 15 January 2012 - 04:53 AM
-1996 850 Turbo
-2007 XC90 V8
Posted 15 January 2012 - 10:07 AM
Quote
Given the information here is correct, then shoot for the injector that will suit your power range.
Can anyone confirm this info? I mean it was written about 8 years ago lol.
#14
Posted 15 January 2012 - 01:07 PM
#16
Posted 15 January 2012 - 02:33 PM
#17
Posted 15 January 2012 - 03:49 PM
I think you will enjoy it. Keep the wastegate not too crazy because this turbo SPOOLS quickly. I can't stress that enough.
#18
Posted 15 January 2012 - 05:39 PM
#19
Posted 15 January 2012 - 05:48 PM
rbodor3, on 15 January 2012 - 05:39 PM, said:
I keep seeing people say this... but I haven't had one fail on me except for my own neglect... and I beat it badly.
#20
Posted 15 January 2012 - 06:50 PM
Rbodor3, I see in your sig that you are running 19T with 2001 2.4 LPT, is it with stock internals and how is it holding up? I'm planning on a similar combo for a 2000 V70 R.
2000 V70R, 108,000 miles, Emerald(Olive) Green/Graphite, Father and son project car awaiting engine swap.
My wheels: Changes almost daily but usually a Volvo of some sort
