98 N/a Cams In 98 T5
Posted 17 January 2012 - 12:58 PM
Thanks gang
Posted 17 January 2012 - 01:33 PM
im here ftw, on 17 January 2012 - 12:58 PM, said:
Thanks gang
They will work.
Posted 17 January 2012 - 01:57 PM
Posted 17 January 2012 - 02:28 PM
850 GLT can be turbo or N/A (97 is turbo, the rest N/A)
So it's 94-98 N/A cams.
Posted 18 January 2012 - 05:26 AM
1991 244 NA - M47
Posted 18 January 2012 - 11:49 AM
Posted 18 January 2012 - 01:02 PM
Deimos, on 18 January 2012 - 11:49 AM, said:
Edited by dublin14, 18 January 2012 - 01:12 PM.
Posted 18 January 2012 - 01:11 PM
Edited by dublin14, 18 January 2012 - 01:17 PM.
Posted 22 January 2012 - 06:04 AM
If by "aggressive" you mean 0.5mm more lift on one of the cams (not both), then yeah. haha. They're like a half-mod. Not quite a sport cam set, and IMHO, not worth installing unless you're really bored, or you have to remove the OE cams anyway (lifter replacement, head gasket...).
N/A Cams:
Inlet Duration = 250°
Inlet Lift = 8.45 mm
Exhaust Duration 252°
Exhaust Lift = 8.45 mm
T5 Cams:
Inlet Duration = 242°
Inlet Lift = 7.95 mm
Exhaust Duration 243°
Exhaust Lift = 7.95 mm
can't edit, but there you go.
855 Turbo Automagic :: T3/T4E .60 + E85 = fun!
4 gears, 5 cylinders, 7 seats...13 seconds.
