Front Parking Lights Do Not Operate
9 replies to this topic
#1 Vagabond
Vagabond
  • 922 posts
Posted 17 January 2012 - 01:51 PM
My Front corner lights do not operate as parking lights. Swapped bulbs to no avail.
All the indicators work, (2 front, 2 Fender, two Rear), Head lights , Tailights, Rear Parking lightsand brake lights all work.
Just not the front parking lights. Besides posible corrosion on the contacts, any reason for this?
I also bent the little tabs forward for better contact.
1994 850 NA 189,XXX mi. Coming Soon: Mo Flow...
The Build
http://volvospeed.co...ou-get-for-200/
Eclipse AVN5435 6.5 inch Navigation For Sale...
#2 smokin' T5M
smokin' T5M
  • 936 posts
Posted 18 January 2012 - 12:48 PM
Is the signal getting to the connector? If so, I would suggest new sockets.
#3 Vagabond
Vagabond
  • 922 posts
Posted 18 January 2012 - 01:45 PM
I have extra sockets i can try.
What should voltage read?
The Build
#4 James A Sousa
James A Sousa
  • 307 posts
Posted 21 January 2012 - 12:44 AM
The headlight switch fell apart in my daughter's '95 855. She lost her headlights.
It is not difficult to remove it - what broke was the tabs that held the guts in the box around the switch.
Does your headlight switch feel funny?
I purchased a new switch, but later decided that a simple repair with tape that does not stretch would have done the job.
#5 Vagabond
Vagabond
  • 922 posts
Posted 21 January 2012 - 03:11 AM
The Build
#6 BEJinFBK
BEJinFBK
  • 1,760 posts
  • Gender:Not Telling
  • Interests:Lottsa stuff!
    The world is a big place...
Posted 21 January 2012 - 03:45 AM
If the rear parking lights are working, the fronts should be, too.
Check power on pin 3 at the back of the light housing.
The book says it should be a white wire on the
driver's side and a green wire on the passenger.
Ground is the black wire in the middle on pin 2,
but if the turnsignals work up front, then it's OK.
Check the pins inside the sockets for power, too.
Sure you have the right bulbs?
Looks like the license plate lights are tied into the
driver's side parking circuit. Are those working?
#7 Vagabond
Vagabond
  • 922 posts
Posted 21 January 2012 - 03:52 AM
bulbs are 1157.
I'll check the plate bulbs, and test those wires.
Thanks. Solid info.
The Build
#8 s_moneh
s_moneh
  • 1,166 posts
Posted 21 January 2012 - 04:24 AM
Do u have those aftermarket angel eye headlights? If u do, apparently the bulbs r single stage therefore will not stay on, ud have to find dual stage ambers/clears to work.
If u dont have those headlights im out, these people have some great info
#9 Vagabond
Vagabond
  • 922 posts
Posted 21 January 2012 - 01:59 PM
no
The Build
#10 Vagabond
Vagabond
  • 922 posts
Posted 05 March 2012 - 10:59 PM
Still cant figure out why this is.
The Build
