850 Front Lip (How To Retrofit Vw Passat Lip)
how to lip 850
14 replies to this topic
#1 DoriDori
DoriDori
  • 79 posts
  • Interests:Japanese muscle cars, drifting, engine theory, my handy down Volvo 850, fabrication, theology, soteriology, eschatology, local churches, non-profits, healthy eating, fitness, gardening, college graduate
Posted 18 January 2012 - 06:30 AM
After getting what parts I needed off a donor 850 at my local junkyard, I began to mock up random lips off several cars to the junk 850's front bumper. I was having a blast! After test fitting several I really liked, I decided to go with the lip from a 1992 VW Passat. The material was flexible, its very simple to remove from the Passat, its European, texture and color matched the trim on the 850, the curves actually complimented the 850's bumper, and I think it just looks hot!.
(Also note the Passat lip is actually 2 pieces making it easy to mock to your Volvo bumper. The driver side slips into the passenger side leaving a flush look with about 2 inches of adjustability. )
Time: 1.5 Hours
Part Cost: $5 from Junkyard
Tools you'll need:
1. The tabs VW used to secure the lip to the Passat need to be cut or ground down so the surface can mate flush with the 850s bumper. I used a fresh razor blade but I suppose a Dremel tool could also do the job.
(before)
(after)
2. The passenger side of the lip has several "circles" left from the manufacturing. Use the razor (or Dremel) to make the circle closest to the mating joint flush with the plastic.
(before)
(after)
3. Mock the two lips pieces into position on your 850 bumper. I used C-clamps to hold it in place. I'm sure there are many other ways to hold in place. The lip will not sit perfectly flush with the 850 bumper. In some places it juts out more than others but take time and shift it into a position that is pleasing to the eye. To center the lip, I measured the distance from the mating point on the lip to a reference point on the 850 bumper.
4. With the bumper positioned how I liked it, I began to drill holes through the lip and bumper one at a time. Once a hole is drilled, run a cable tie through it and tighten securely without moving the lip or the clamps. Only remove a clamp when it is covering a tab you wish to drill through. Doing this will keep your end result looking exactly how your mock up looks. When starting to drill, I began in the middle and worked my way to the outside while taking a step back every other hole to make sure the lip didn't shift in a way I didn't want it to. I drilled and hole for a cable tie about every other tab. The more the better because at cruising speeds you don't want the lip to be loose.
5. Finished!! Once I replace the burnt exhaust valve and get it running again I will take some better pictures. She is a MESS right now!
#2 Oreo931
    Level 8 Senior Member
  • 23,659 posts
Posted 18 January 2012 - 06:34 AM
Good effort and nice write up. Do you plan on extending the sides of the lip so it sits flush with the sides of the bumper?
#3 DoriDori
DoriDori
  • 79 posts
Posted 18 January 2012 - 06:48 AM
Yes, I do. Next time I'm at the junk yard I will grab another Passat lip haha.
#4 Jesus
Jesus
  • 4,698 posts
Posted 18 January 2012 - 02:11 PM
Not bad.
#5 Logan2224
Logan2224
  • 1,124 posts
Posted 18 January 2012 - 03:52 PM
Nice! I'll be doing a similar thing with an early 90s Accord lip. Rob and I discovered that a while back. Thanks for the great write up! It'll be a big help
02 C70 Coupe - 92k, Silver/silver, 6000K HIDs, EST intake, IPD HD TCV
#6 RobT5.
RobT5.
    Doctor Retardapus
  • 3,093 posts
  • Interests:We-mons
    Orange Soda
    Speeding
    Archery
    Cars
    Poking
    Your Mom
Posted 18 January 2012 - 04:01 PM
:lol: I still have that lip chillin at the house.
still upset it fits a stock 70 bumper perfectly and not an R bumper. <_< but w/e.
Dori nice job!
1998, S70 T5.
RobT5 FloridaVolvoCommunity Car Domain
Quote
optimus prime when i do get this whole project underway im totally gonna eat a sandwich in my engine bay
#7 DoriDori
DoriDori
  • 79 posts
Posted 19 January 2012 - 01:21 AM
Dori nice job!
Thanks, Guys! Is the s70 in your sig equipped with the Accord lip? Looks great!
#8 RobT5.
RobT5.
    Doctor Retardapus
  • 3,093 posts
  • Interests:We-mons
    Orange Soda
    Speeding
    Archery
    Cars
    Poking
    Your Mom
Posted 19 January 2012 - 02:41 PM
Nu thats a volvo 960 lip :) Cut/bondo'd to make it fit.
1998, S70 T5.
Quote
#9 Mattphi
  • 8,403 posts
Posted 19 January 2012 - 02:51 PM
Posted Image Posted Image
#10 JVC
  • 7,604 posts
Posted 19 January 2012 - 02:59 PM
View PostMattphi, on 19 January 2012 - 02:51 PM, said:
I would plastic weld or fiberglass and bondo the center crack so it's not visible. I just saw this lip at the junkyard yesterday and was confused why it was already cut in the middle... Needless to say I picked up a 740 Lip instead.
#11 Ian Carr
Ian Carr
  • 1,386 posts
  • Interests:Autos, design, photography, beer.
Posted 19 January 2012 - 03:35 PM
better pictures would help
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
#12 exexpat
exexpat
    Projector Gadget
  • 7,428 posts
Posted 19 January 2012 - 08:58 PM
That duck bill style was functional on Passats, too. The grille-less front end and behind-emblem intake snorkel meant all air to the radiator came through the lower front bumper. Needless to say, they didn't always cool well in arid climates.
That said, I'm not sure about it. I like the duck bill from the front, but wish the sides were an inch deeper.
I'm "X to the P" and I've been pimped...
I use www.airbagit.com for air ride and www.motorsport-tech.com for custom adapters and I like them both
#13 kalvin
  • 1,645 posts
  • Interests:Pirates, Cars, Random Acts of Awesome
Posted 19 January 2012 - 10:04 PM
This. Looks awkward from the side.
96 855T - (NVRGNGVUUP)
ARD Green M4.4 @ 17psi, 18x8 Borbet Odysseus, "Modified" D2 Racing Coilovers, Cherry Turbos Strut Brace, iPd Sways 25/25, Fujita Intake, Snabb Intake Pipe, NA TB+960 plate, NA Intake Manifold, iPd Phenolic Intake Spacer, 2.5in Magnaflow Catback
#14 Guest_luke_jones_*
Guest_luke_jones_*
Posted 20 January 2012 - 02:25 AM
Well done getting it on there, fits the profile nicely. But I agree about the side. If you could mod it to something like this would flow better I think.
#15 Yellow95
Yellow95
  • 5,665 posts
  • Interests:Porn and pork skins
Posted 20 January 2012 - 03:09 PM
Shave the front of your wheel wells. :)
1998 S70 T-5M, 1996 854 Turbo, 1998 V70 T-5M SOLD, 1998 V70 T-5A SOLD, 1996 854 Turbo SOLD, 1993 244 SOLD, 1991 244 SOLD, 1998 V70 T-5M (18T) SOLD, 1985 245 Turbo SCRAPPED, 1982 245 Turbo SOLD, 1997 854 GLT (16T) SOLD,1995 854 Turbo (18T) SOLD, 1997 855 T-5 SOLD, 1996 854 TLA (18T) SOLD
