Is An Engine That's Has Been Sitting For 3 Years Still Good?
13 replies to this topic
#1 VulVer
VulVer
  • 76 posts
  • Interests:Hockey,European cars
Posted 18 January 2012 - 08:25 AM
I have the opertunity to get an engine with 80k on it for an amazing price. But here's the catch the engine has been sitting for 3 years, dry. I'm scared the insides have rusted by now and if I was to try and turn the engine by hand the rust on the piston rings could cause them to break or crack. I would obviously fill the engine with A very thin oil an let it sit for some time but I still have a fear of this. I need help, suggestions and an engine. Thanks guys.
#2 dimka18
dimka18
  • 395 posts
Posted 18 January 2012 - 08:29 AM
Engine wont get rusted inside unless it had contact to water, the seals are most likley not going to be very good but it shouldnt be rusted.
1996 Volvo 855R, M56H, 16T, 3in DP, Custom exhaust, Tune, 16psi mbc. More to come
Posted ImagePosted Image
#3 Keaton85
Keaton85
  • 6,439 posts
Posted 18 January 2012 - 01:53 PM
Redo the all of the seals and fill the cylinders with marvel mystery oil, then turbo the motor over by hand.
3 years is nothing, if you wanna talk about some time, let's talk Land Rover motors! soaking them in marvel mystery for months on hand just to get them to move....
Although if you are really worried then you could pull the head, so that would let you look and the cyclinders, and the valve springs.
#4 VulVer
VulVer
  • 76 posts
Posted 18 January 2012 - 07:14 PM
Thanks guys I heard fill the engine with penut oil and spray kroil in the cylinder heads let it sit for a day and turn by hand until it gradually gets easier. How does this sound ? Any tips pleasedelete ? Your always good with info like this. And whatdo you mean what's the big deal about landrover motors ?
#5 Keaton85
Keaton85
  • 6,439 posts
Posted 18 January 2012 - 07:26 PM
I would just put marvel mystery oil in the cyl and turn it over by hand. It won't take but a few turns...
I'm talking land rover as a lot of these old motors have sat for a decade or so without being moved.
#6 Lucky
Lucky
  • 2 posts
Posted 20 January 2012 - 09:05 AM
Did the engine come from a wreck or did it get pulled because it had problems? Can you turn the motor now and feel if it is compressing? Take two hours and take the head off. Then you'll know what you are dealing with. Use a penetrating oil like wd40/liquid wrench/PB and spray all the rings until they are loose. Do this while it is out otherwise you're just installing it to rebuild it later. While it is in half you can evaluate if any rust has occurred with the valves, their guides and how bad the seats look.
Funny you should mention it I have an old '65 series 2a sitting in front of the house right now. An electrical nightmare, like most of them, it has sat for periods of years but once I track down all the parts it still starts and runs.
1997 855R
#7 Jardim
  • 1,276 posts
  • Interests:Being a Volvo Rat. Eating, drinking water, sleeping, working, etc.
Posted 21 January 2012 - 09:08 PM
80K mile engine huh? Where was the engine sitting for 3 years? If it was inside your golden, i'd still run some lucas or marvel like the other guys said just to be safe.
Now had the engine been sitting outside, i would rebuild the head, you dont want valve springs breaking on you...and the seals would probably be completely junk.
94 854 T5M----------------Volvo Rat
#8 volvoskiah
volvoskiah
  • 1,301 posts
Posted 21 January 2012 - 10:51 PM
Engine has been sitting inside, It will probably need valve seals and oil sump o-rings etc.
98 S70 GLT-M * 79 242 GT * 96 850R * 84 F150 * 99 S70 AWD
72 Chevrolet K10 Cheyenne*78 242 GT*98 S70 T5*00 V70R*04 V70R*96 855R *97 855R*98 V70R*98 V70R*99 V70R*99 V70R*98 V70 NA*98 V70 XC
#9 Jardim
  • 1,276 posts
Posted 21 January 2012 - 11:07 PM
But other than that it's a 80k engine, in volvo terms barely broken in :lol:
#10 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 22 January 2012 - 01:50 PM
Sitting inside? If you dont buy it i know someone who might
#11 VulVer
VulVer
  • 76 posts
Posted 24 January 2012 - 05:50 AM
Ya sorry guys I've been away skiing. Ya under 80k sitting dry inside for 3 years. He wants 200 for it. Now here's the thing it has a cracked oil pan but he has a new one with everything bolts, seal. But if it was cracked for all that time wouldn't moisture get inside? I mean their has to be a little and for those just joining the thread I don't know if I'm going to rePlace my headgaskit or just drip in a new engine yet if I decide to fix my engine pm me I can give you the kids number only kicker is that if your not in the new England area it might be a hassle but I willet everyone know. Thanks
#12 Jardim
  • 1,276 posts
Posted 24 January 2012 - 05:53 AM
200 bucks?
LMK
#13 VulVer
VulVer
  • 76 posts
Posted 24 January 2012 - 06:00 AM
Ok pal I'll let you know. I'm prob going to bring my car down to my mechanic this week so I'm going to have to make a decision very soon.
#14 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 24 January 2012 - 10:57 AM
if the pan is cracked, and the engine was indoors with the cracked pan still on, then there isn't going to be much moisture in there. Was it cracked, or did a fragment fall out, leaving a hole in it?
Honestly, I would still just pop the head off and have a looksie...really easy thing to do with the engine already out...
I would throw down the $200, and take a risk with it, and just hope that it's fine...chances are that it is...i understand that not everyone is in the same position to do so, but if you can, then you should! and if he's willing to let you take the head off before you buy it, it's going to take you an hour, tops....spray some PB Blaster on the nuts overnight, and have at it in the morning.
if it's good, you pay another $100 to have the head resurfaced and cleaned, and a new headgasket, and you're set man.
