Should I Replace The Timing Belt?
Posted 18 January 2012 - 07:40 PM
It turns out that the exhaust cam seal is leaking, from the looks of the oil build up under the timing cover its been leaking for a little while.
I have the Blue gates racing Timing belt on the car now need less to say it was covered in oil.
I know drying oil will tend to crack and dry out rubber.
But does anyone think the gates belt will be safe, or should I just drop the $27 on the OEM belt to be safe..
What would you do?
16T/NXS MBC/Turbo Back/OBX V2 Strut Brace/Blueprinted, port &Polished head/N/A Cams/ARD Tuned/Samco I/C Hoses/Snabb Stuffz
Posted 18 January 2012 - 07:57 PM
Posted 18 January 2012 - 08:39 PM
The blue on the belt isnt even discolored.
Ill give it a shot... thanks
Posted 18 January 2012 - 11:54 PM
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
Posted 19 January 2012 - 12:28 AM
Ian Carr, on 18 January 2012 - 11:54 PM, said:
Posted 19 January 2012 - 01:22 AM
bergmjs, on 19 January 2012 - 12:28 AM, said:
No thats not the reason, I just figured because the belt is basically new and there was no physical damage aside form the oil on it.
Just wanted to know What were other peoples thoughts on re-using it thats all.
After buying the Seals, Loctite, and 2 quarts of oil
I just dont have the extra $35 till the end of the month to get a new belt. Still playing catch up from X-mas
I trust your guys opinions and advise, If you guys said "dont trust it and replace it" Id pull the battery, and let the car sit until I got the belt..
Posted 19 January 2012 - 05:21 AM
Posted 19 January 2012 - 05:25 AM
It's a kevler belt at that!
Posted 21 January 2012 - 12:32 AM
What mileage? - What time?
Posted 21 January 2012 - 12:58 AM
Unless someone wants to try out and see how long a kevler belt lasts!
