Blower Stuck On 4. 96 850
Posted 19 January 2012 - 12:48 AM
Blower motor is stuck on high. Switch doesn't change speed or turn it off. Blower goes off when I pull either the speed fuse (30A) or the 1-3 speed fuse (25A). (Or turn the car off)
_No_ lights on the control (Recirc/AC). I believe it may be the automatic AC version as the fan speed selector has an AUT option.
Should I replace the stage or is it likely something else?
Posted 19 January 2012 - 03:05 AM
The MCC has a "Full Speed" (speed 4) relay that overides the speed control
resistors that give you speeds 1-3. You'll find it next to the blower, behind the
glove box. It's marked as # 2/24 in the diagrams. That relay gets energized by
putting the speed switch in position 4. If fuse 31 shuts it down, you probably
have a monkeyed up speed switch. Check for 12 volts at pin 86 on that relay.
If it doesn't drop off when you take the switch off of speed 4, get a new switch.
96 850 MCC Diagrams.pdf 297.27K
2 downloads
96 850 MCC Component Locations.pdf 419.4K
2 downloads
Posted 19 January 2012 - 03:42 AM
This car is North America OBDII - no diagnostic unit. (Not that I could get a code with the REC and A/C lights not working.)
Seems most other users with a blower problem have a functioning ECC. There is only fuse 5 and 31 before the ECC, right?
Posted 19 January 2012 - 07:01 AM
850 MCC panel.jpg 110.62K
12 downloadsDoes the fan control have 4 speeds?
850ECC panel.jpg 146.21K
14 downloadsOr is it continuously variable, with a setting marked "AUTO"?
Posted 19 January 2012 - 12:21 PM
Posted 19 January 2012 - 06:33 PM
Just change the power stage/blower resistor and you will be fine ! If you need one for cheap, PM me, but I'm in Canada...
It is the one for the ECC : http://www.fcpgroton...limate control)
easy to change... under the glove box !
95 854 T5-M
Posted 19 January 2012 - 10:24 PM
If it's ECC, you probably do need a new power stage.
Posted 19 January 2012 - 11:41 PM
Posted 19 January 2012 - 11:50 PM
But the stages usually go because the motor kills it.
Check that out, too.
Posted 20 January 2012 - 04:16 PM
True, mine was loose on the blower motor bearing and it was doing some noise... changed both and it's now good !
95 854 T5-M
Posted 21 January 2012 - 09:46 PM
Also, I read a thread at Matthews Volvo site about overhauling an ECC power stage. It may not work. There is also a thread about the MCC resistor/speed control and the diode in it can be replaced rather easily.
Posted 21 January 2012 - 10:49 PM
It's a thermal fuse.
Posted 22 January 2012 - 04:30 AM
You are correct and my bad... Thermal Fuse... FWIW means what?
#14
Posted 22 January 2012 - 05:35 AM
( And , FWIW, I used to know the value of
that fuse, but I have dun fergot...
