Limp Mode, More Problems
5 replies to this topic
#1 Dmsee
Dmsee
  • 6,579 posts
Posted 19 January 2012 - 01:45 AM
While I almost narrowed down to my ETM being bad, the check engine light came on yesterday
I scanned for codes and got
P0455
P0440
P0446
evap emission codes leaks..
After erasing these codes car behaves weird idles at 1500rpm sometimes and sometimes barely stalling the message reads :
Also car goes into limp mode, if I restart it its fine but goes to limp mode eventually
Are these codes effect the idle or my ETM is just shot?
Any ideas? Thanks for any input
#2 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,809 posts
Posted 23 January 2012 - 02:10 PM
Most likely unrelated I should think.
99 V70R
98 V70 GLT
#3 Keaton85
Keaton85
  • 6,439 posts
Posted 23 January 2012 - 03:34 PM
Are you planning on doing the ETM soon?
#4 Dmsee
Dmsee
  • 6,579 posts
Posted 23 January 2012 - 10:53 PM
Already done with Xemodex, so far so good
Looking for a tune now
#5 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 25 January 2012 - 04:34 AM
So you've installed the xemodex recently?
The evap codes will not cause a poor running condition, unless something unusual is happening like the evap valve is stuck open and your a topper upper, so the charcoal canister is filled with raw fuel and it's being sucked into the intake.
Edit: I'd start looking for an evap leak, likely at the J hose that comes out of the charcoal canister.
98 S70 T5M
#6 Dmsee
Dmsee
  • 6,579 posts
Posted 25 January 2012 - 10:16 PM
Replaced the purge valve so far no codes.
