Koni Str.t Strut
Posted 20 January 2012 - 04:21 AM
http://www.tirerack....95&autoModClar=
I've done a search on here and volvoforums.com, and tons of reading about suspension setups and not found anything Volvo specific.
Does anyone know anything about these or have any real world tests/opinions?
Posted 20 January 2012 - 07:28 AM
Posted 20 January 2012 - 04:09 PM
Posted 20 January 2012 - 04:14 PM
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT/MegaSquirt 3X - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
Posted 20 January 2012 - 04:15 PM
fischmama, on 20 January 2012 - 04:14 PM, said:
Frank Derks from EST posted not too long ago about these. You can find the thread here:
http://volvospeed.co...ni-strt-shocks/
00' V70 NA 15XK Miles
84' 242 shell at the moment
Posted 20 January 2012 - 05:15 PM
98 C70 HPT M
Posted 20 January 2012 - 09:56 PM
Str.t are the budget alternative and their valving is supposedly similar to the yellows on the very soft setting. I have no idea of their build quality and I'm pretty sure they are gas-charged vs. the yellows being oil-charged. Obviously, they aren't adjustible, where the yellows have adjustible rebound (compression is static).
Over the years I've learned that dampers are THE thing not to cheap out on when modifying the car. But, they should work just fine as an OEM replacement, I'd rank them in the same range as KYB GR2s which I put on my LS400.
Stan
Posted 23 January 2012 - 04:43 PM
1995 855 Turbo M 16T | Upsolute tune | and moar
Posted 23 January 2012 - 08:09 PM
RZT5, on 20 January 2012 - 05:15 PM, said:
I have Koni sports on the front of my AWD with TME springs. I have to say I've never set them to anything softer then full stiff. But I'm use to running Bilstien HD and LOVE how stiff they are.
NEUBAR
