Help Identify Vac Line
#1 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
  • Gender:Not Telling
Posted 20 January 2012 - 08:38 PM
what is this line that is right below the vac tree underneath the vac line for the cbv. It is connected to the gold color nipple and it is a pretty thick line, where does this go to and what does it do, mine is definitely leaking and was wondering if it would cause any issues? heres a pic:
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
#2 Oreo931
    Level 8 Senior Member
  • 23,659 posts
Posted 20 January 2012 - 10:28 PM
That goes to the brake booster and any leaking vacuum hose will cause issues. The line goes under the airbox, connects to a nipple, then to another hose going to the brake booster. Pop out the airbox and you'll see exactly where it goes. Easy fix.
#3 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
Posted 20 January 2012 - 11:45 PM
sweet , thanks.
#4 vmaxx
vmaxx
  • 240 posts
Posted 21 January 2012 - 03:12 AM
Oreo next time you two should wear your seatbelts!
1997 850 T5..ARD Green/K&N Panel/IPD Parts/MSD/Silicone Everything
156MPH Sleeper...
