Found A Source For Clear Headlight Lens For Early X70's
lens for hid retrofit
24 replies to this topic
#1 fasteddyT5
fasteddyT5
  • 151 posts
Posted 20 January 2012 - 09:49 PM
I know a lot of people have been looking for sources for clear headlight lenses for 98+ X70's. I just got in a set for my 1998 S70 for an upcoming hid projector retrofit project from Autolampsplus:
http://stores.channe...m/autolampsplus
They are $50 a side for DOT approved glass lenses with new clips and seals. They ship out of south Florida, two pairs cost a total of $216 shipped to Portsmouth, NH.
They come from the same source as the lenses on the ABM projectors. They aren't listed on the website so you'll need to call. I talked with Josh several times and he was great to work with. I haven't tried mounting them yet, but holding them up they look like they should fit well. I'm hoping to do the retrofit next weekend so I'll post back when I do.
1998 S70 T5M
Portsmouth, NH
#2 db130
db130
  • 771 posts
Posted 20 January 2012 - 11:54 PM
which HID projectors are you going to be working with?
2000 V70XC SE, 162k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 233k '00R 302s DIY AEM BCS/IPD Stage 1 ECU/IPD 3" Turboback
Check out the Delco BCS/TCV
#3 fasteddyT5
fasteddyT5
  • 151 posts
Posted 21 January 2012 - 12:54 AM
I got an FX-R kit from the retrofit source. I've test fired them and they look very nice. I haven't opened up the headlights yet, hopefully they will not be to big. Holding them on top of the headlights it looks like it will be a somewhat tight fit.
1998 S70 T5M
Portsmouth, NH
#4 tizio
tizio
  • 523 posts
Posted 21 January 2012 - 05:01 AM
Nice find, what is the diff. in between the FX-R you have and the Mini H1 4.1?? in diameter they are the same 2.5 inch lenses if i remember correct.
98 S70 T5 M56H,R clutch,manifold , 04 RN engine, Black on black,Koni+Ipd Black, IPD Sways, OZ racing 18X8,282K, 00'V70R silver/black STOCK for now. 99' C70 Vert., 02' S60 AWD.
#5 fasteddyT5
fasteddyT5
  • 151 posts
Posted 22 January 2012 - 03:32 PM
Yes, they are both 2.5" lenses. It looks like the mini's are only about 1/4" less deep than the fx-r's, which is the important dimension. The big difference in terms of dimensions is that the fx-r has a larger mounting frame around it, but there looks to be plenty of space for the frame inside the reflector.
As for performance, my understanding is that the FX-R is a better projector but requires more modifications to install. The H1 mini is supposed to be very easy to put, almost plug and play they say. You can see a comparision of different projectors here:
http://www.hidplanet...o-FX-IS-e46-LR3
1998 S70 T5M
Portsmouth, NH
#6 tizio
tizio
  • 523 posts
Posted 22 January 2012 - 05:41 PM
Many Thanks for the link, make things very easy !!!
#7 fasteddyT5
fasteddyT5
  • 151 posts
Posted 22 January 2012 - 07:08 PM
I'm hoping to do the install this upcoming weekend. My brother and I each have kits we're putting into our '98 x70's. We're planning on taking pics as we go and putting up a post about it.
1998 S70 T5M
Portsmouth, NH
#8 agravadr
agravadr
  • 22 posts
Posted 07 February 2012 - 04:24 PM
how was mating the glass lenses to the OEM assembly? any fitment issues?
'98 S70 T5M
#9 D s50r
D s50r
  • 1,516 posts
Posted 08 February 2012 - 07:32 PM
are these still available to buy? i cant find them on the website
98 midnight blue s70 glt se
#10 Burn-E
  • 9,319 posts
Posted 08 February 2012 - 07:38 PM
#11 D s50r
D s50r
  • 1,516 posts
Posted 08 February 2012 - 07:47 PM
o0o0o reading would work i guess ahah thanks
#12 fasteddyT5
fasteddyT5
  • 151 posts
Posted 12 February 2012 - 04:05 PM
No fitment issues at all, they are direct replacements for the stock fluted glass. They are held in using the stock clips and seals (they do come with new seals and clips by the way. I'll put a picture up soon of the new headlights when I get on my other computer.
And yes, you need to call or email for these lenses.
1998 S70 T5M
Portsmouth, NH
#13 burnout8488
burnout8488
  • 730 posts
Posted 12 February 2012 - 07:25 PM
http://www.ebay.com/...9#ht_1747wt_945
Here as well, they have both the left and right lenses.
'99 S70 AWD + FWD Trans // 161K
2.4+15g/Rmani/Snabb Pipe/EST DP/ARD Green/4300k Bi-Xenon Retrofit/Nivomats/Rear Heated Seats
#14 fasteddyT5
fasteddyT5
  • 151 posts
Posted 12 February 2012 - 09:01 PM
These lenses have the same manufactures part number as the ones I got from Autolampsplus, so these should be good for anyone looking for a set of clear lenses.
Just a note, it cost me $16 to get 4 lenses shipped from Autlamps location in Maimi to Portsmouth, NH.
1998 S70 T5M
Portsmouth, NH
#15 fasteddyT5
fasteddyT5
  • 151 posts
Posted 15 February 2012 - 05:30 PM
Here are two pictures of the new projectors installed behind the clear lenses. I still need to go back in and install the shrouds but we ran out of time doing the original install.
Inside the photo album are some other shots of the build.
1998 S70 T5M
Portsmouth, NH
#16 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 15 February 2012 - 05:52 PM
Looking good. Curious as to high beam performance with stock high beams through clear lense. Also curious as to your method for getting the projectors level and aligned.
99 V70R
98 V70 GLT
#17 (n)A-GAME
(n)A-GAME
    Chief Investigator
  • 7,645 posts
Posted 15 February 2012 - 06:16 PM
They'll be useless spotlights blinding everyone and everything, hazardous and useless at the same time. They were not designed to be used without fluted glass. The only way to properly do this would be do a second projector in the high beam location, I forget who but another guy on here did that and it turned out pretty good.
2011 Volvo S60 T6 AWD Polestar | 2000 Volvo V70 R AWD
#18 Burn-E
  • 9,319 posts
Posted 15 February 2012 - 06:55 PM
That or install a bi-xenon projector and turn the hi-beam into a daytime running light with LEDs
#19 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 9,771 posts
Posted 15 February 2012 - 08:44 PM
How does a high-beam blind someone, if you should only be using them when others aren't around?
86 Kawasaki Gpz900R Ninja
#20 Dan A
Dan A
  • 1,994 posts
Posted 15 February 2012 - 08:52 PM
Ditto. I was actually more curious on the difference in output.
99 V70R
98 V70 GLT
