V70 Ac Working Intermittenly
air conditioning ac
#1 ranissi
ranissi
  • 4 posts
Posted 21 January 2012 - 10:30 PM
On my V70 (170k miles), the AC will work for weeks, then stop working, work again for a week ... with no apparent reason/relationship to outside influences like temperatures etc. The system is fully charged and when it works, cooling perfomance is great. There has been some noise coming from the vents/control panel but I assume this completely is unrelated and has to do with the baffles and airflow control. The control panel lights have blinking a couple of times, but do NOT seem to correspond directly to the compressor not engaging. Lights might flash and the AC will stop working a week or two later.
When the AC works, the compressor engages and there is a clear clicking, which I assume it either the a seloniod or the clutch enaging.
I've read about the clutch gap being an issue with V70 ACs not engaging. Could this be the case and explain the randomness?
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 21 January 2012 - 10:36 PM
Clutch gap and or low freon...
#3 ranissi
ranissi
  • 4 posts
Posted 23 January 2012 - 01:11 AM
Thanks ... the system is fully charged, so I'll check the clutch gap ...
