I purchased the Lubri Moly Jetron / Lubri Moly Valve Cleaner / Lubri Moly Oil additive today. Firstly, I added both the Jetron and Valve cleaner to my full gas tank. I did not read anything on the labels that said not to and the NAPA guy said that it would not hurt. Any experience/testimonials with these products from any of you. Should I be concerned that I added both products at the same time? Hope not! My car is a 2002 S60 2.4T with approximately 193000 mls.
Thanks!
Lubri Moly Additive Questions
Started by marsman, Jan 22 2012 09:48 PM
4 replies to this topic
Posted 22 January 2012 - 09:48 PM
Posted 22 January 2012 - 10:02 PM
Why?
Posted 26 January 2012 - 01:55 AM
Why not? Was my question. After about a half tank of premium fuel consumed. I am getting a 1.7 MPG increase. I also changed my spark plugs. I plan on running the Lubri Moly products in my car this year to see how it performs/MPG increase.
Posted 26 January 2012 - 02:24 AM
1.7mpg due to spark plugs not due to the additives.
What are you trying to gain from adding these? do you have an issue with the vehicle?
Posted 28 January 2012 - 12:21 AM
Yes, it was not idling smoothly. I am still experiencing what seems like low power under load (like going up a hill) but my car downshifts and it pulls good if I give it gas. I was under the impression that these additives could possibly help with rough idle ( no change in RPM at idle - probably not my ETM), clean my ignition system out. I did have a good bit of oil pooling in one of the spark plug wells. So, at spark plug change out I cleaned everything up with Q-tips before spark plug replacement (last done about 35,000 to 40,000 miles ago). I have had my PVC system changed/serviced at about 140,000 mls (currently at 193.000 mls). I've purchased an IPD HD CBV and have yet to install it. Maybe my issue could be caused by this (original CBV in use now)? I have not checked my PTC to see if It is clogged. It is a bear to detach from my intake hose. Could this reduce performance? I replaced my coil packs at about 80,000. Do you think it may be a coil pack? Only code that I have gotten has been P0171. The check engine light went out after I changed my spark plugs ( Volvo OEM Made in Germany).
