I'm Planning On Replacing The Turbo In My Xc With One From A 94 850
Started by cbpldc, Jan 23 2012 12:50 AM
9 replies to this topic
Posted 23 January 2012 - 12:50 AM
Will I need a tune, or a manual boost controller? Or will it just work, albiet a bit less efficiently.
It will accompany a new PCV system, ETM, head gasket, boost hoses and timing belt, water pump, tensioner and rollers.
Chris
Chris
96 850R (rescued from the junkyard)
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 23 January 2012 - 12:59 AM
Get a T5 ecu with white injectors. Or don't bother as it won't help you any. Why are you replacing it?
Never mind, you have a 99-00?
But still why?
But still why?
Posted 23 January 2012 - 03:21 AM
99-00 = Straight or Angled flanged (idk which one, i dont own one)
94 = Conical flanged hotside.
You would either need to swap DPs or housings to get it to work.
94 854 T5M----------------Volvo Rat
Posted 23 January 2012 - 03:22 AM
'94-95 = Conical
'96-98 = straight
'99+ = angled
'98 S70 T5M - Broken
'96 855R - IPD stg. 3
'95 854 T5-R - Slow
'95 854 T5-R - Slow
Posted 23 January 2012 - 03:36 AM
94 conical
95 split
96-98 straight flat
99 split
00 conical
I beleive that is more accurate.
Not hard to just swap the turbo itself and leave the exhaust side alone.
95 split
96-98 straight flat
99 split
00 conical
Posted 23 January 2012 - 05:16 AM
please delete, on 23 January 2012 - 03:36 AM, said:
94 conical
95 split
96-98 straight flat
99 split
00 conical
95 split
96-98 straight flat
99 split
00 conical
I believe that's not accurate at all
Anyway, 15G swap is a nice upgrade. Will have to leave the existing exhaust housing though (as mentioned).
Will not HAVE to upgrade the injectors or tune right away, it'll run fine in the meantime. It is recommended though (at least the tune; many will argue that the injectors aren't needed) to get the full potential of the upgrade. I drove my '00 for a few months after the 15G swap before installing blue injectors and a tune. Pulled a little harder, but max boost was the same...
Anyway, hope this helps
Joe
Posted 23 January 2012 - 03:13 PM
I thought that 95 and 99 had a mix of both? i swear I've seen straight flange 95s and 99s.
The main question is are you replacing the turbo because you think it's bad or because you want to upgrade?
Posted 23 January 2012 - 09:12 PM
I wouldn't run a 15G on an ECU tuned for a 13T. As long as you just swap the compressor/center cartridge, you don't have to worry about the exhaust side at all.
Get an ARD tune for that turbo mated to your LPT motor and call it a day!
Posted 24 January 2012 - 12:45 AM
That's what I was thinking. The car is slow. If I could get a tune, bump the mileage and have a pinch more speed, I'd love that. I can swap the exhaust housing no problem.
Chris
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 24 January 2012 - 12:54 AM
Why year? And we are saying that you don't need to change the exhaust. Also talk to lucky about a tune fr 99-00 if that's what you have.
