V70R Ecu Plug N' Play? Or Need Supporting Mods?
ecu v70r
11 replies to this topic
#1 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 23 January 2012 - 02:57 AM
Might be a silly question........I want to upgrade the ECU in my 98 v70 t5 and found a decent deal on a R ECU....
So like it says can I just plug n play or do I need to modify a few things?
Also will that change the boost or do I need to run a BC?
Thanks.
#2 (n)A-GAME
(n)A-GAME
  • 7,288 posts
  • Crew:ECC
Posted 23 January 2012 - 02:59 AM
850R or V70R? V70R fine, 850R not fine.
2011 Volvo S60 T6 AWD
#3 mdlimy
mdlimy
  • 2,933 posts
  • Interests:Beer, volvos, boost <3
Posted 23 January 2012 - 04:18 AM
yes 98 v70r ecu is plug n play, you will see some more boost, no supporting mods needed but letting the exhaust breath a bit more would help the spool time slightly.
View PostJVC, on 13 March 2012 - 05:56 AM, said:
You sir... just keep on winning...
#4 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 23 January 2012 - 05:12 AM
Thanks for the replies.
Need to double check that's a v70r and not 850r. I am working on the intake side right now. Planning on doing exhaust in the near future, kinda doing my build as I find the best deals....
#5 ARD - Lucky
ARD - Lucky
  • 792 posts
Posted 23 January 2012 - 05:39 AM
If it's not what you need, PM me as I have more than a few "R" cores of both 850 and 70 series.
#6 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 23 January 2012 - 05:55 AM
Will do. Thanks lucky.
#7 98t5M
98t5M
  • 435 posts
  • Interests:Computers, Electronics, Motorsports, Food, Beer.
Posted 23 January 2012 - 07:24 AM
Make sure it's from a 98 also.
It really won't gain you much, probably 5whp, so unless it's real cheap I would just get a tune or mbc instead.
#8 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 23 January 2012 - 02:20 PM
Does the current ECU work well with a boost controller? Someone said it doesn't work well.
Unfortunetly the guy didn't specify upfront it was for an 850 R.....so I will be sending lucky a message ;)
#9 mdlimy
mdlimy
  • 2,933 posts
Posted 23 January 2012 - 08:36 PM
Do your mods then just buy an ard tune from lucky for those specific mods, best way to do it.
#10 ARD - Lucky
ARD - Lucky
  • 792 posts
Posted 23 January 2012 - 11:06 PM
Just PM when you're ready and I'll be happy to help!
#11 98t5M
98t5M
  • 435 posts
Posted 25 January 2012 - 09:17 AM
If I recall correctly you can turn up the boost a couple psi without the ecu freaking out. Again though, your best bet is just to get a tune.
#12 ARD - Lucky
ARD - Lucky
  • 792 posts
Posted 26 January 2012 - 03:58 AM
14psi is the typical fuel cut point for M4.4 so an MBC/EBC can be used to that point, although there is some risk of connecting rod damage with MBC...
Also tagged with ecu, v70r
