93 - 94 Aluminum Control Arms -Where Are The Weak Points?
11 replies to this topic
#1 deadchane
deadchane
  • 125 posts
Posted 24 January 2012 - 11:33 PM
I'm in the process of reinforcing my 93 - 94 aluminum control arms.
Before my welder gets started, he would like to know where the stress / weak points are on the arms in order to reinforce accrodingly.
Any guidance is appreciated.
These were just blasted:
1998 V70 AWD
1998 C70
1999 S70
#2 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 25 January 2012 - 01:06 AM
The aluminum.
#3 Kevin.
    Dick Dabber
  • 5,447 posts
  • Interests:United States Air Force
Posted 25 January 2012 - 01:20 AM
I heard Kaplhenke has some super awesome control arms
95 850 GLT | Tropic Green Metallic | 219k | ARD Tune | M56H | E-Code Conversion | Full LED interior
2W131L - USAF
#4 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 25 January 2012 - 01:24 AM
Kidding aside its going to be the hard mounting points.
#5 Kevin.
    Dick Dabber
  • 5,447 posts
Posted 25 January 2012 - 01:25 AM
Oh cmon Chuck it was funny and you know it
2W131L - USAF
#6 Keaton85
Keaton85
  • 6,439 posts
Posted 25 January 2012 - 01:31 AM
Those are hard to find!
Even worth using?
#7 Platinum850Wagon
Platinum850Wagon
  • 218 posts
Posted 25 January 2012 - 01:49 AM
I'm running them on my car. No problems as of yet.
1996 855 Platinum Edition/2nd owner/Stainless Steel Brake Lines/Red Calipers/OBX V2 Strut Bar/Silicone Plug Wires/850R ECU/Memphis, TN
#8 tizio
tizio
  • 315 posts
  • Interests:all engines, some cars,space, ho knows
Posted 25 January 2012 - 05:15 AM
Even worth using?
Lighter then iron one, you can change ither way the bushing or the pivot depends on witch go loose, and you are not force to change the whole control arm.
#9 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 25 January 2012 - 05:23 AM
But also not as stiff.
#10 Keaton85
Keaton85
  • 6,439 posts
Posted 25 January 2012 - 07:10 AM
Is that from personal experience :lol:
#11 Johann
  • 4,979 posts
Posted 25 January 2012 - 09:06 AM
Officially these arms also need different uprights which a slightly different shaped at the steering stop area.
As they are they perform well but hardly noticeable. Only advantage is the separate steering knuckle.
If you want to reinforce these I would say forget it and go for the steel arms.
#12 tizio
tizio
  • 315 posts
Posted 25 January 2012 - 01:45 PM
True. For someone aka lighter wen hit the wallet .
