Posted 25 January 2012 - 02:28 AM
Posted 25 January 2012 - 02:55 AM
i recommend wideband, boost gauge, new turbo drain gaskets.
Posted 25 January 2012 - 03:24 AM
Posted 25 January 2012 - 03:39 AM
tune soon afterwards, b/c you'll be throwing codes a lot.
you probably won't have to, but you can check the waste gate setting too. There's a thing on ipd's web page "how to" do that. pretty straightforward.
Posted 25 January 2012 - 03:44 AM
Posted 25 January 2012 - 04:07 AM
but honestly I wouldn't bother driving it anywhere until you have it tuned. that's a great way to end up with an engine rebuild
Posted 25 January 2012 - 04:21 AM
Posted 25 January 2012 - 09:14 AM
lentez7, on 25 January 2012 - 04:21 AM, said:
I second not driving it with the 18t without a tune.
Posted 25 January 2012 - 12:51 PM
I don't know yet I haven't had time to check but I think its the straight, its still has the stock Turbo so it would be straight right?
Posted 25 January 2012 - 06:04 PM
Posted 25 January 2012 - 06:46 PM
lentez7, on 25 January 2012 - 06:04 PM, said:
I suggest you spend some more time doing research and reading up on what people have done in the past with these cars, the do's and don't, and what will and will not work. This will be much more beneficial than bolting on random parts and not knowing what to do.
Vent pods: http://bprayventpods.webs.com/
#14
Posted 25 January 2012 - 06:53 PM
#15
Posted 25 January 2012 - 07:41 PM
lentez7, on 25 January 2012 - 06:53 PM, said:
I would suggest contacting Lucky at ARD Tuning (ARDideas.com) with your desired plans and he should be able to provide some suggestions and point you in the right direction.
#16
Posted 25 January 2012 - 07:46 PM
And have Fun!! Make a thread everyone likes to follow the LPT builds
#17
Posted 25 January 2012 - 08:18 PM
#18
Posted 26 January 2012 - 04:24 AM
yes, tuning is expensive, Lucky @ ARD is making it more affordable for good tunes, but he's still a bit out from getting to the 01 cars. I'm in the same boat as you waiting for a tune.
take the time between now and then to collect the pars and installing the supporting mods.
add tranny cooler if you're running an auto, add ipd HD CBV diaphragm or a blanking plate with BOV
#19
Posted 26 January 2012 - 05:38 AM
Ok got it. Thanks
