Violent Idle When Warm
4 replies to this topic
#1 rcaddell
rcaddell
  • 95 posts
Posted 25 January 2012 - 05:51 PM
Corss posting form my thread on V70R.com :
Have an issue with my 2000 V70r. Once the engine warms up, the idle gets VERY rough. Almost to the point where you think it is going to stall. Car starts running rich. Once moving, all seems fine. Recently did the PCV system and 02 sensors. Rechecked for vac leaks, none to be found. If I unplug the maf, idle shoots up as normal, engine smooths out for a few seconds, the starts running rich and idling poorly again. Only trouble codes are for front o2 and upper fuel limit. Any ideas? On the verge of walking away from it and getitng something newer. Thanks
2000 V70R
1995 SHO
2007 FXDC
#2 brad850
brad850
  • 636 posts
Posted 25 January 2012 - 06:04 PM
Check the vacuum line going into the passenger side of the intake manifold.
ahh I just realized you said you have a v70r. If there isn't a vacuum line there disregard my post lol.
But if there is check it. Mine was unplugged and I had the same exact symptoms.
96 850R
Fmic, N/a throttle body, Ipd ecu, bilstein HD's, strut brace, qbm endlinks, sconeman pipe
Infinity speakers/sub
#3 Keaton85
Keaton85
  • 6,439 posts
it's on 00, not a 98! there is a vacuum line in that area but it doesn't fail like the 94-98 series does.
You either used the wrong O2 sensor, the splice went bad,or you have a vacuum leak.
#4 rcaddell
rcaddell
  • 95 posts
Posted 26 January 2012 - 01:10 PM
Going ot recheck for vac leaks this weekend. i used an O2 from FCP, perhaps I should just get one form volvo
Thanks!
2000 V70R
1995 SHO
2007 FXDC
#5 Honeyman
Honeyman
  • 222 posts
  • Interests:dogs, gardens
Posted 26 January 2012 - 04:17 PM
Displaying similar symptoms, my issue was a bad seal between the charge-air tube and the ETM. I had folded the lip upon re-install. The PCV work leads me to believe it is vacuum related....fwiw.
1999 V70R LB 245,000 mi. CAI, Snabb, DP, Duals, RICA, ac delco tcv, 302 slotted/dimpled, IPD sways, konis/euro nivos, Pegs/Sats
1998 V70R saff 115,000 mi. IPD duals, ecu, sways, tubular skid, Pegs/Comets
1996 850R black 190,000 mi. CAI, 16t, ARD, s60 mani, DP, exhaust, eibachs, canistos, work in progress.
