Posted 25 January 2012 - 07:36 PM
Any advice or other ideas? Anyone know if Speedtuning in MD can do this?
NEUBAR
Posted 25 January 2012 - 09:13 PM
I shot an e-mail to the guys at C'Ville V. Will let you know how they respond...
1998 V70R saff 115,000 mi. IPD duals, ecu, sways, tubular skid, Pegs/Comets
1996 850R black 190,000 mi. CAI, 16t, ARD, s60 mani, DP, exhaust, eibachs, canistos, work in progress.
Posted 25 January 2012 - 10:16 PM
Meaning, an ECU taken from another car cannot be re-programmed to work in your car. Volvo dealers have no such software. That being said Lucky is working on being able to re-program ECU's, but I don't know where he's at in the process.
Read through this thread and some of your questions may be answered.
http://volvospeed.co...46780-ard-tune/
Posted 26 January 2012 - 12:45 AM
The only other option is to purchase a new ECU from Volvo and have it programmed or get a used ME7 ECU and see if someone with VIDA/DICE can reload it for you, again will have to be in same place as the car.
Posted 26 January 2012 - 12:50 AM
And this is Luckys ME7 thread.
AJ, thanks for your help it's appreciated! I'll buy ya a beer at the Mad Fox..
ARD - Lucky, on 26 January 2012 - 12:45 AM, said:
I have the used ECU, my spare... I guess I shouldn't be calling it spare since I can't use it at the moment. So can you go into deal what this VIDA/DICE process is?
NEUBAR
Posted 26 January 2012 - 01:11 AM
I have one that I use for reading/programming cars but you have to have the car in posession to be able to program any of the modules through this method. There's a way to get the IMMO pin code that is easier but I haven't worked it out yet. I may be able to get the CEM to spit the Immo code out on the dash instrument cluster (data center) in which case cloning ME7 becomes a cake walk... for now though ME7 decoding has taken the majority of my attention.
Posted 26 January 2012 - 03:42 AM
Personally tried this when I worked at the dealer, absolutely does not work. Only the FTS has the "special" software needed to do this, and good luck trying to get that done.
Posted 26 January 2012 - 03:53 AM
Ultimately I want Me7 ECU's to be as interchangeable as M4.x ECU's... I'm working on it now... few tricks up my sleeve
Posted 26 January 2012 - 04:49 AM
Fantastic news! Anyway you can provide the software to users with VIDA? The software I witnessed in action (FTS supplied) was able to re-program every module except the CEM, which I was told was engineer level. Any chance you can do this with a variety of modules?
Posted 26 January 2012 - 06:10 PM
NEUBAR
Posted 26 January 2012 - 08:27 PM
Posted 26 January 2012 - 08:34 PM
Ihatespeedbumps, on 26 January 2012 - 04:49 AM, said:
That would be sweet! I've got Vida and am very interested. Might even be able to help out NEU, since he is close by.
Posted 26 January 2012 - 08:40 PM
I do have one other way we could read out the immo code but it's not terribly DIY friendly.
Involves me sending the equipment to read out the ECU to someone and guide them through the process. It's not terrible hard but requires removing the ECU from the car, snapping an in circuit reader in place and installing some software to read it out.
Would look something like this:
#14
Posted 26 January 2012 - 08:44 PM
NEU, on 26 January 2012 - 06:10 PM, said:
The only people that have the "special" version are Volvo Field Technical Specialist (FTS) who work in different regions around the country, they don't operate out of a single dealer. They are dispatched to dealers when a very complicated issue arises (usually warranty work) to get help resolve issues. The FTS has is own laptop with a special version of VIDA that is not available to the dealers. With this he can go much more in depth into control modules, and even has the abilty to re-program every module in the car except the CEM.
What I'm saying is, no dealer is going to help you out with this. Best of luck.
#15
Posted 26 January 2012 - 08:47 PM
#17
Posted 26 January 2012 - 10:56 PM
andyb5, on 26 January 2012 - 08:58 PM, said:
Edited by ARD - Lucky, 26 January 2012 - 10:57 PM.
#18
Posted 27 January 2012 - 04:33 AM
#19
Posted 27 January 2012 - 04:50 PM
#20
Posted 27 January 2012 - 06:31 PM
BTW I owe you a couple rounds for that...
NEUBAR
