Pnp Switch Removal
Started by blackANDwhite, Jan 26 2012 07:15 AM
9 replies to this topic
Posted 26 January 2012 - 07:15 AM
I have yet myself to try it, but someone with a parts car is trying to remove it for me, and they can't figure out how to remove it. My issue is that I don't have my car torn apart to look at it and tell him how to. Though from what I understand this part is the reason I can't shift out of park with out using the little button next to the shifter. So any photos and info would be great!!!
Oh and off topic and Ihave yet to look anyone have a power antenna unit they would like to part with? Some nice guy thought when mine was frozen up, it would be a good idea to bend it over.... PM me on that please if you do.
1997 850 GLT 2.4 Turbo stock... beater.... ****SOLD****
1997 850 T5 2.3 Stock, Silicone hoses, Debadged blacked out grill, 95 2.3 engine, drop in K&N
1987 Jeep Cherokee (Terakee) too much to list for mods
Posted 26 January 2012 - 07:21 AM
The PNP switch doesn't link to you not being able to shift out of gear without the button.
Posted 26 January 2012 - 07:29 AM
correct, there is a shift solenoid next to the auto gear shifter, under the trim..i forget the exact name for this...shift lock solenoid or gear selector sensor....gear position sensor or something like that....
most likely that's what has gone bad...pretty simple to replace from what i can recall.
Posted 26 January 2012 - 07:33 AM
ok well... that part then, I told the guy it was the solenoid, but was also told it was called the pnp switch, either way any tricks on how to remove it and such?
Posted 26 January 2012 - 12:44 PM
I believe its the following...
http://www.fcpgroton...(Genuine Volvo)
Edited by prasamin, 26 January 2012 - 12:48 PM.
Posted 28 January 2012 - 04:58 AM
The Groton price shown is $4.10 higher than the MSRP they show...also, thier writeup says this is for manual transmission.
Posted 28 January 2012 - 05:33 PM
OP: The PNP switch mounts on the transmission. That switch also goes bad frequently, but the symptoms are different (up arrow on th dash, backuplights not coming on, shifting oddities).
Posted 30 January 2012 - 12:15 AM
A bad electrical portion of the ignition switch can also cause the gear selector to not move. You can try jiggling the key to see if you can shift.
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
Posted 30 January 2012 - 05:08 AM
Good post bergmjs, I didn't know that. Going to try it on my own car, thought the microswitch was acting up.
