01 T5 Head On 97 850
Started by volvo, Jan 27 2012 12:39 AM
Posted 27 January 2012 - 12:39 AM
Well , I spun a bearing in my 01 motor and since my 01 head is entirely rebuilt, im going to drop in the 97 T5 block w/ the 01 head.
I used the 01 headgasket but I drilled out a few holes that the 97 headgasket had that this didnt,
Did i fukc up? SHould I have just left 01 headgasket stock and not drilled the extra holes that were in the 97 headgasket?
thanks.
thanks.
1998 Volvo V70 GLT : R/N 2.3 T5 block : 57 Trim T3/T4 : 11 psi 40mm ext. wg : M56H : ZEX Nitrous Kit : Aquamist
ARD Tuned : 3 Inch everything : 30 x 18 x 5 FMIC : N/A TB : Ported/Polished : APEXI AVC-R : Greens : More
Posted 30 January 2012 - 01:13 AM
so you drilled holes in the HG? shouldnt be a problem, but yea the HG matches the head. very few changes in the block except the cyl bore, at least as it comes to the head gasket. just make sure the head is going to sit flush and no crowning around your new holes...
Posted 02 February 2012 - 03:01 PM
thanks much!
