Long Range Wireless Router
internet wireless computers
35 replies to this topic
#1 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 27 January 2012 - 01:13 PM
Need to buy a long range wireless router....or strong signal
Problem i face right now is lack of signal due to contruction here....solid concrete walls etc
Need signal to penetrate through 4 floors of concrete in my entire building so i can skype or surf when i am in my flat on the 4th floor, or on the terrace on the floor right above me, or in any one of the 8 flats in my building
Looking to keep my total cost under 100 dollars....around 50 even better lol...only need it for the 6 months i am here
#2 Mesoam
  • 18,673 posts
Posted 27 January 2012 - 01:27 PM
some have signal strength built in have you checked the admin settings? by default I think they're on a lower setting
96 854 R, CLICK ME
The Jeep
#3 Spanky
Spanky
    Has a boner for Adam's Dad
  • 1,534 posts
Posted 27 January 2012 - 02:13 PM
I was pulling a signal in from a few miles away a couple of years back with a grid antenna and a couple of custom pigtails, and some low loss cable. I believe what your looking for is a "repeater/expander" but I could be wrong.
Contact me for turbos, turbo parts and rebuild kits
#4 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 27 January 2012 - 03:09 PM
I have a DD-WRT Linksys which I'm messing with right now. I'm cranking up the antennas, but I doubt it's going to do the trick. I'll report back tomorrow.
I'd like to keep it as simple as possible. When I leave, my parents will come stay here on and off, so if I can just get a single router with crazy antennas or the like, then it would make life much easier for them.
The Netgear I'm currently using does not have an option to crank the antennas up, nor is it DD-WRT or Tomato compatible. Let me report back on the Linksys. It has internal antennas also, which might be holding it back some.
#5 Mossback
Mossback
    Old Man Crew Sgt at Arms
  • 1,632 posts
  • Interests:Volvos
    SciFi
    My kids
    Staying married (25 years)
Posted 27 January 2012 - 05:10 PM
I sell industrial wireless, we traditionally use commercial WiFi access points with external antennas.
Some high gain antennas are available for home AP's (like this)
http://www.hdcom.com...hzantennas.html
If there is still a problem, you need to at minimum get the antenna to the other side of the wall. (Note: Rebar and mesh fencing can create a significant RF barrier.)
If you're trying to get further away there are also patch and parabolic (directional) antennas, but any way you cut it, internal antennas are a fail for this type of capability.
01 C70M
Garage
1 of 603
#6 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 27 January 2012 - 06:26 PM
we have rebar only in the supporting pillars...the walls are literally solid brick and concrete....
so can i get a typically dd-wrt/tomato flashable router and add an omni directional antenna and get significant gains?
I just tested the signal on my Linksys DD-Wrt with internal antenna, and i am only good within my flat and outside at the lift and down to the flat right below me....if i go to the terrace, or below the 3rd floor, no luck with connecting to my network
#7 db130
db130
  • 724 posts
Posted 27 January 2012 - 06:57 PM
with dd-wrt you should be able to increase the signal output
2000 V70XC SE, 149k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 135k '00R 302s/Delco TCV/IPD 3" Turboback(taken off the road)
1998 S70 T5, 223k DIY AEM BCS/IPD Stage 1 ECU
Check out the Delco BCS/TCV
#8 Mossback
Mossback
  • 1,632 posts
  • Interests:Volvos
    SciFi
    My kids
Posted 27 January 2012 - 09:36 PM
Make sure the antenna is rated for 5 to 9 db gain. another element is the 802.11 ratings have different range characteristics directly proportional to their bandwidth.
This is illustrated when we deploy WiFi at a truck yard. We set the radios exclusively to 802.11b (the least bandwidth) or G, to get the furthest range. This band tweaking process would be secondary to firmware and antenna upgrades.
01 C70M
Garage
1 of 603
#9 Hanks
Hanks
  • 3,374 posts
Posted 27 January 2012 - 10:08 PM
powerline ethernet then setup another router upstairs. ~100$ for both brand new.
#10 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 7,693 posts
Posted 27 January 2012 - 10:12 PM
agreed
40+ mods and counting...
#11 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 January 2012 - 03:13 AM
I have 3 routers sitting here...
i am now using the Linksys with DDWRT as my main router connected to my incoming WAN wire
Would it be possible to place the other 2 routers in different locations of my house and use them as range extenders without powerline adapters?
basically have the 2 routers connect wirelessly to the main router in the bedroom, so that if i am in closer range to either of them, i can get a strong signal?....use them as repeaters or whatever it's called...
View Postdb130, on 27 January 2012 - 06:57 PM, said:
already went into DD-WRT and cranked the internal antennas all the way up...only getting a minimal improvement in signal
#12 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 January 2012 - 03:28 AM
You are going to need two devices at the min. You also are going to need to be in the 2 watt range if you are even dreaming of IEEE 802.xx. If you do not need a lot of bandwidth you can go to ULF bridges. Either way, you will need two devices as your mobile device will not have broadcast power you need. You are in India. Sure there is a 5watt cellphone jamming device of a router around there somewhere for under 5 dollars.
#13 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 January 2012 - 04:24 AM
I just need to access the internet when i'm drinking on the terrace, or chilling downstairs....my internet connection is $75 per month, and I'm getting 1.5Mbps up and down...so I don't need any bandwidth...i just need to be able to surf the internet or watch my slingbox from anywhere in the building.....i would think a router with Tomato or DDWRT, and a strong pair of external antennae would do the trick??
#14 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 January 2012 - 06:11 AM
Issue is really power. Your laptop probably has a 200mw antenna, and your router maybe 800 if you are lucky. So even if your laptop sees your router the router will not be able to see the laptop. Hence you are going to need mulltiple WAPs.
#15 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 January 2012 - 06:48 AM
Ok, so is it possible to use my extra router as an access point to sling around my wireless signal?
I guess kind of like a hotspot which gets it's internet connection from my main router?
yeah, the Linksys router i have with DDWRT is maxed out at 251mw.
Edited by prasamin, 28 January 2012 - 06:49 AM.
#16 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 January 2012 - 01:30 PM
So i was able to set up my ddwrt loaded linksys as a repeater, and placed it at the other end of the flat......works so far on both ends of my terrace, and need to check downstairs tmro.....
Unfortunately as soon as i crank the antenna up past 50mW, it takes a dive every few minutes.....assuming its heating up too much....need a ddwrt router with more extreme tolerance so it can transmit further
#17 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 28 January 2012 - 02:59 PM
Yes and those are not under 50 dollars each. For distances you are talking I would say ~2000mw or hang what you have out the window.
#18 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 January 2012 - 05:42 PM
yeah, looks like ddwrt goes up to 251mW....not gonna cut it on the linksys.....i need to keep an eye out for something that can get me atleast 1000mW and place them in different areas of the house.....i have seen outdoor antennas but i cant really keep a window open for wiring pass through.....i have the repeater and router at oppo9site ends of the house, adjacent to windows....i may need to rig up cooling for the repeater so i can experiment by turning it up to max
heard good things abt a hacked wrt54g linksys...gonna research that a bit
#19 bdimag
bdimag
  • 3,806 posts
  • Interests:Computers, Electronics, Volvos, Audio...
Posted 28 January 2012 - 05:49 PM
can you throw some heatsinks or fans on it somewhere? didn't i see a write-up for that on the webs?
Brian
'91 244 (project: never-gonna-be-finished-because-im-fucking-lazy)
'04 S60 2.5T (dd/old man car) | '92 245 | '02 C70 2.3HPT Coupe
#20 PyROTech
PyROTech
  • 5,342 posts
Posted 28 January 2012 - 07:07 PM
http://www.data-alliance.net/ got some nice stuff from them. have this http://www.data-alli...olic/Detail.bok
also if you want super easy...
http://home.cisco.co...1000/RE1000.pdf
have 2 of these and could not be more simple.
EDITED PART: i also have some alfa usb wifi adapters... have this http://www.data-alli...00mW/Detail.bok and this http://www.data-alli...-USB/Detail.bok
Edited by PyROTech, 28 January 2012 - 07:24 PM.
