99 Xc70, Boost Comes On Quick, Then Cel And Reduced Power
Started by cbpldc, Jan 27 2012 03:29 PM
14 replies to this topic
Posted 27 January 2012 - 03:29 PM
I haven't had the code scanned, but the light goes off after about 2 hours of drive time if I don't really hammer on it. Where should I start? Anyone seen anything like this before?
Thanks,
Chris
Thanks,
Chris
96 850R (rescued from the junkyard)
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 27 January 2012 - 04:04 PM
Waste gate is stock closed due to vacuum, the cotter pin or a bad waste gate actuator.
Either way, you might brake something if you keep it up like this!
Posted 27 January 2012 - 06:36 PM
Cotter pin is in. The vacuum line is hooked up. I'll check the actuation of the wastegate when it cools down. If wastegate functions, then what?
Thanks.
Chris
Thanks.
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 27 January 2012 - 06:48 PM
check the codes.
also does it feel like the car is too responsive before you get the cel?
99 v70xc x2 sold
Posted 28 January 2012 - 02:40 AM
P0234. Overboost, or something. Yes. Feels super quick, then the CEL comes on, and then I'm slow.
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 28 January 2012 - 02:48 AM
It's regulated by your waste gate so.... make sure it's actuating correctly.
Posted 28 January 2012 - 03:03 AM
Ok. That will be my morning project. Is it possible that the wastegate is seized or something? Or the actuator? Either way, I'll check it and see what's going on. There's also some kind of sensor that has 3 vacuum lines coming out of it and a couple of wires thats sitting next to the airbox. I'm assuming that a turbo control valve of sorts?
Thanks for the assist guys.
Chris
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 28 January 2012 - 05:38 PM
Okay. It seems that the wastegate was sticking and the vacuum line from the control valve was cracked and rotted. Lubed the wastegate and replaced the line. Good linear boost across the board and no CEL!
Thanks for the assist, guys.
Chris
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 28 January 2012 - 10:47 PM
Crap! CEL back on with the same friction' code.
Any ideas?
Any ideas?
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 28 January 2012 - 10:55 PM
Probably the same thing, sticking or vac lines are bad.
Posted 28 January 2012 - 10:58 PM
Okay. Here's how it goes. If the light is going to come on, it does it right at startup. If not, it doesn't come on now. Would that indicate sticking WG?
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
Posted 28 January 2012 - 11:17 PM
P0234 come up and then goes away? after idling or what?
Posted 29 January 2012 - 12:11 AM
Nope. After driving it a couple of times not getting on it, the code goes away. Or at least, the light goes off.
Chris
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
#14
Posted 29 January 2012 - 12:17 AM
Probably sticking...
Idle up to temp, open the hood and rev the motor manually while watching the waste gate actuate.
#15
Posted 30 January 2012 - 03:19 PM
Okay. Found the issue, I think. Two of the vacuum lines on the TCS were routed incorrectly. Boost now comes on when its supposed to and stays on.
Chris
Chris
94 940 Wagon
99 V70XC
94 940 Wagon
99 V70XC
