Hello Forum,
I've run across an issue while attempting to hook up the Sc-815 in my 850 to my just purchased USASPEC adapter.
I have hooked up the adapter, but I'm afraid I spliced the wrong wires behind the stereo, I used the wire numbering on the large connector (there are little numbers near the socket) and I spliced the red and yellow to the red and yellow number one and two wires. Now, my HU won't clear with the code and I can't get the iPod to play through the adapter.
I am sure that some people have this in their car, and anyone who would be willing to take a picture to show me exactly which two wires to splice would be greatly appreciated. I'm not very confident in my electrical ability when working on cars, so I would prefer not to screw up again.
My car is a 1997 850 T-5, if that makes any difference.
Thank yo very much in advance!
6 replies to this topic
Posted 28 January 2012 - 06:41 AM
Posted 29 January 2012 - 06:43 AM
Aftermarket power wire colors follow the EIA/TIA color code:
Red is switched
Yellow is constant
Black is ground
Cars use a wide variety of colors and most brand differ.
Never assume that the colors will just match up.
Look it up and get out a meter and be sure.
Looks like you're trying to pull power off
of our front left dash speaker output.
For your Volvo:
Constant power is Green/Brown on pins A4 & A12
Switched power in Yellow/Violet on pin A13
Ground really is Black on A6 & A14
Still - Always get a meter out and double check.
Red is switched
Yellow is constant
Black is ground
For your Volvo:
Posted 29 January 2012 - 07:54 AM
I'm no electrician, one of the wires is tagged with "accessory" and the other "power" from the adapter, there isn't a clear ground, unfortunately. I guess I'm frustrated because the instructions weren't as clear as they needed to be.
Which do I hook up to the green and which to the violet?
Posted 29 January 2012 - 09:21 PM
Red is Switched - (Accessory)
Yellow is Constant - (Power)
Black is ground
For your Volvo:
Black is ground
For your Volvo:
Posted 30 January 2012 - 04:47 AM
Thanks, wasn't reading carefully so late at night. I'll hook it up and give it a try, is it possible to hook up the wrong wires and ruin the HU? The SC-815 I have won't accept the code anymore.
Posted 30 January 2012 - 06:15 AM
The HU will only display CODE if it loses power.
If the incorrect code is entered more than 3 times,
it'll lock up and say OFF. Leaving the radio on for
two hours ( even if it does say OFF...) will fix that.
Just be sure that you have the correct code for round 2.
And yeah - If you short a speaker output, you can fry a radio.
Check fuses 7 (constant) and 32 (switched) and check it out.
Hopefully, it's only a blown 7 fuse.
Posted 30 January 2012 - 06:09 PM
Okay, thanks a bunch!
Also tagged with ipod, 850, sc-815
Announcements →
Show Room →
The Cat, It Has Escaped From The Bag!Started by kalvin, 20 May 2012 |
Modifications →
Performance Modifications →
Digital GaugesStarted by maximumbuckeye, 15 May 2012 |
Announcements →
Member Announcements →
Snabb Fmic Thread.. Gauging Interest... With Pics!Started by sconeman, 15 May 2012 |
Modifications →
Cheap 850 Downpipe/exhausts?Started by maximumbuckeye, 14 May 2012 |
Maintenance →
FWD/AWD 1998 and Prior →
Volvo 850 Turbo Main End Bearings?Started by Gigawit_Anteon, 10 May 2012 |
