Ground Points For The 96 850 Turbo
9 replies to this topic
#1 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
  • Interests:Volvo's, football, and finishing school.
Posted 28 January 2012 - 10:04 PM
I want to check the ground points for the engine and would like to now where they all are. I know the one in the back of the engine is there any others?
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 28 January 2012 - 10:31 PM
Right below the starter on the block looping up from the subframe.
#3 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 28 January 2012 - 10:34 PM
http://www.___.com/d...ing_diagram.pdf
this is for a 95, but all points should be the same.
In the index it has a list that says "Ground Points" under section 2.4 (bottom of page 61) there are images and locations of the engine grounds. I believe there are 8 total in the engine bay that are relavent to what you might be looking for.
#4 pedro fandango
pedro fandango
  • 301 posts
  • Interests:anything silly with a petrol engine
Posted 28 January 2012 - 10:48 PM
the link doesn't work, looks like the forums editted the address out
#5 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 28 January 2012 - 10:57 PM
thanks for the info guys. Time to get dirty. the car decided it didn't want to start last night after a hard rain. trying to trace it. checking grounds first.
#6 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 29 January 2012 - 12:34 AM
odd. just got to Mathews Volvo Site. search for wiring diagrams, then select the diagram for a 95 850. go to page 61 and it will show in detailed pictures all ground points in the engine bay.
#7 hotfoot
hotfoot
  • 19 posts
Posted 29 January 2012 - 03:23 AM
Not to wander away from your particular issue, but it does remind me of my (much missed) 240 DL wagon, which suddenly decided the winshield wipers had to beging anytime i turned on the headlight....the Bricyard froum led me to a couple really hidden grounds...one behind the battery, and the other (which was the culprit) under the carpet, next to the gear shift lever...a place I never would have thought to look...
So it may well be in some mysterious spot where some devious Swede chuckled as he put pen to paer on the drawing board! :P
(no edit button, I see...better check my spelling next time! Sorry!)
#8 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 30 January 2012 - 10:35 PM
thanks for the info and references fixed it . found the loose ground in the lower front near the alternator. tightened it up and no more problems as of yet. thanks again
#9 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 30 January 2012 - 10:45 PM
Awesome. Glad it was a simple fix.
#10 BEJinFBK
BEJinFBK
  • 1,760 posts
  • Gender:Not Telling
  • Interests:Lottsa stuff!
    The world is a big place...
Posted 30 January 2012 - 11:50 PM
It probably didn't like the PDF file extension. Here's the index page link:
http://www.matthewsv...iring-diagrams/
