Xc90, Need To Know The Good, Bad And The Ugly?
Posted 29 January 2012 - 01:34 AM
SOLD: 96 850 GLT 37k miles (yes, 37k miles), now at 63k miles ;-)
Posted 29 January 2012 - 01:38 AM
Posted 29 January 2012 - 01:53 AM
these guys are wrong then?
http://www.autotrade...&standard=false
and
Posted 29 January 2012 - 02:04 AM
Posted 29 January 2012 - 02:23 AM
Posted 29 January 2012 - 02:38 AM
- proven power plant
- proven drivetrain
- dem issues
- angle gear sleeve
- eats control arms
- eats balls joints
- eats inner tie rods
- eats outer tie rods
- eats brake rotors
- probably needs new headlamps...hazing
- sunroof drain clog
- touch anything inside the dash and you might set off the SRS service urgent message
- third row seat might jam and not fold back down
look here for a guide http://xcforums.com/..._1193#entry1193
these are the common problems that may have been addressed already prior to your purchase. dont be scared from my bad list, its just common things that go bad over time.
Look at me, i have the lemon of lemons from the xc90 line up, yet i still love it. still would dump money into it to keep it road worthy.
Posted 29 January 2012 - 03:29 AM
Not knowing much about the awd operation, what's the worst case scenario? replace what and how much? Is it possible to remove the driveshaft going to the rear and operate in fwd mode alone? I might be wrong but think this is possible on the v70 series.
Posted 29 January 2012 - 04:39 AM
Posted 29 January 2012 - 01:33 PM
Posted 29 January 2012 - 02:02 PM
autel 702 $200 ish
example: you turn off tracs, and do a burn out in a awd car = awd no workie
scan tool spits out dem 0007 code = $100 pressure switch + $25 fluids + 1 hour (20 minutes when you get good at it) of your time = $$$$ saved over the dealership wanting to sell you a $2000 haldex unit
Or it can need a awd sleeve, $100 part + 8 hours labor for a diy. its nothing for a VS'r, a little dirt under the nails is ok.
Posted 29 January 2012 - 02:06 PM
Posted 29 January 2012 - 02:23 PM
Rear seat sticking (as steve already listed)
some of the LEDs in the head unit are out.
high beams do not stay on (wife doesn't even know what high beams are
One ball joint replaced
And now the engine seals (common on all white block 5cyl.)
The climate control vents are prone to breaking as well
Our AWD works fine and we have had no other problems..she put over 40k on it in the last year and a half and has been very reliable..
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
Posted 29 January 2012 - 10:48 PM
Have you checked the obvious like the headlight switch should be in the vertical position? I'll assume you have since you've had the vehicle for quite some time.
2000 V70R, 108,000 miles, Emerald(Olive) Green/Graphite, Father and son project car awaiting engine swap.
My wheels: Changes almost daily but usually a Volvo of some sort
#14
Posted 04 February 2012 - 02:30 AM
Was leather, heated seats standard equipmt? What about xenon?
#15
Posted 04 February 2012 - 02:46 AM
Yeah I have checked all the obvious..they light up for a couple seconds and then revert back to low. probably the switch is bad..
