Question: A/c Compressor Clutch Bearings
#1 Keaton85
Keaton85
  • 6,439 posts
Posted 29 January 2012 - 07:07 PM
Tracked down my serp. belt noise to the AC compressor clutch free wheel unit.
Anyone know if the bearing itself is replaceable or do I have to find a complete clutch assy.?
I'm heading on a road trip sometime this week and most of my time will be down south so I will definitely need the AC working and I can't have this unit fail on the road or it will cost my $1K just to get it sorted. OR buy a belt that works without the AC...
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 04 February 2012 - 09:33 PM
Bearing: 35x55x20
The stock bearing is NTN but idono if I would stick with that bearing for the replacement. MUCH cheaper then buying a new unit...
#3 Keaton85
Keaton85
  • 6,439 posts
Posted 07 February 2012 - 12:42 AM
After a day worth of search I ended up with two 35x55x10 bearings instead of a 20mm unit. Ended up having to go outside of boson for it...
So two 10mm units work just as well as one 20mm. Dot get any made in china! Get some Japan units.
#4 Keaton85
Keaton85
  • 6,439 posts
Posted 07 February 2012 - 01:02 AM
Boston*
