Misfire..
Posted 30 January 2012 - 01:15 AM
Posted 30 January 2012 - 01:17 AM
13.7 @ 99 Automagic
13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
Posted 30 January 2012 - 01:42 AM
Posted 30 January 2012 - 01:44 AM
Posted 30 January 2012 - 01:47 AM
Posted 30 January 2012 - 01:49 AM
You siad they were OEM plugs? Those come pregapped for the specific engines. The factory gap on a T5 is .28
Posted 30 January 2012 - 02:01 AM
Posted 30 January 2012 - 02:10 AM
Are you still running the GLT ECU? that wont keep up with the HPT on a T5, that will cause a misfire.
If you are using a T5 block then you should use the T5 spark gap (.28).
Posted 30 January 2012 - 02:24 AM
Posted 30 January 2012 - 02:45 AM
Posted 30 January 2012 - 03:49 AM
Posted 30 January 2012 - 01:27 PM
Posted 30 January 2012 - 03:14 PM
On the gap, run as wide as you can without geting misfires after you sort out the other hardware issues ^.
#14
Posted 30 January 2012 - 08:49 PM
#15
Posted 30 January 2012 - 08:55 PM
#16
Posted 30 January 2012 - 10:49 PM
But now you know its the wires and you should get those replaced.
#17
Posted 30 January 2012 - 11:14 PM
If there is oil on the plugs it may be bad valve stem seals, remember they are very common. But grayish doesn't sound like oil, I'm talking like crusty deposits.
#18
Posted 31 January 2012 - 12:13 AM
to correct myself replace the plugs.......
#19
Posted 31 January 2012 - 01:10 AM
#20
Posted 31 January 2012 - 01:24 AM
