Euro Headlights
Posted 30 January 2012 - 05:07 AM
Thanks!
98 C70 HPT M
Posted 30 January 2012 - 05:28 AM
95 850 GLT | Tropic Green Metallic | 219k | ARD Tune | M56H | E-Code Conversion | Full LED interior
2W131L - USAF
Posted 30 January 2012 - 06:27 AM
DOT-spec jewels vs. European-spec jewels have different reflectors. According to Sylvannia's website, the US-spec jewels use H11 low beams and 9005 high beams. I'm not sure what/if the European-spec jewels used different bulbs.
JRL has a set of euro-spec jewels on his 00 R, so he'd be able to clarify any differences in bulb type.
Posted 30 January 2012 - 02:41 PM
Posted 30 January 2012 - 03:32 PM
Burn-E, on 30 January 2012 - 02:41 PM, said:
@andyb5, thanks, just need to find someone who has seen the european ones and can verify. Was hoping one of our European members would see this thread.
98 C70 HPT M
Posted 30 January 2012 - 04:31 PM
And before you jump all over me telling me I'm wrong read the entire thread.
Posted 30 January 2012 - 05:12 PM
98 C70 HPT M
Posted 02 February 2012 - 01:32 PM
I have the Ecode lens and they are the best bang for your buck for lighting upgrades. Then after you do that you can upgrade to HID if you want but the difference between Ecode and DOT is dramatic!
This is the only pic I was able to find qucik of the 5w light...
NEUBAR
Posted 02 February 2012 - 01:54 PM
Posted 02 February 2012 - 07:16 PM
98 C70 HPT M
