Led Swap In 850 T5-R Fogs?
37 replies to this topic
#1 maxman142001
maxman142001
  • 129 posts
Posted 30 January 2012 - 05:58 AM
Anyone done it? Part number and source?
1995 Volvo 854R"yellow"
#2 s_moneh
s_moneh
  • 1,166 posts
Posted 30 January 2012 - 05:28 PM
y?
#3 gmsgltr
gmsgltr
  • 3,654 posts
Posted 30 January 2012 - 05:34 PM
^ yup...
y?
throw some hid's in there... they are already projectors... aim em where you want within reason too
- Greg - 96 Red/Tan 855 R 96k miles -
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
#4 maxman142001
maxman142001
  • 129 posts
Posted 30 January 2012 - 05:57 PM
anyone have a part number for HID's that small?
that does sound like a better route. My stock ones are so dim there isnt a point to using them..
#5 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 30 January 2012 - 06:05 PM
You want HIDs with H3C bulbs. More expensive, but better light output as it mimics a stock H3 bulb.
H3C HID bulb on left. H3 HID bulb on right. The right one just does not work as well.
Serge - 95 850 T5
#6 TaskMule
TaskMule
  • 1,151 posts
  • Interests:My car, my pets, my education.
Posted 30 January 2012 - 07:13 PM
LED in fogs are useless. Save your money. Tried a few, all fail. HID is the way to go.
98 V70R AWD
97 855R
#7 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 31 January 2012 - 03:31 PM
good info...will try those bulbs out if i remember!
#8 devolv
devolv
  • 452 posts
  • Crew:ECC
Posted 31 January 2012 - 04:53 PM
Great explanation! I've done my diligence as well and it seems H3C is quite convoluted with many manufacturers using this term incorrectly. The one above is the proper H3C HID Mini bulb, there's another variant around that looks more like something in between that I found.
From left to right: H3C HID Mini, H3C HID, H3 HID (Shortened), H3 HID Standard
Now the question is, is there a reputable seller that carries the above H3C HID Mini bulb? I'm also looking for new bulbs for my fogs. My prior bulbs were DDM H3 HID standard and they did not last long.
Edited by devolv, 31 January 2012 - 04:56 PM.
97 850 GLT LPT 16T - EST Intake - EST Strut - Ferrita Exhaust - KW Coilovers - Undergoing S70/V70R front end retro fit ;)
04 S60 R - 6 MT - Titanium Grey - Nordcap - Sport Kit - Painted Trims - BBS CK 19x8 - CFW CF VST Front Lip - AEM Dryflow Intake - CFW PCC Spoiler - CFW CF Roof Spoiler - Clear headlights + 05+ Custom LED Tails - Eibach Springs - UltraRacing Strut Bar - Autovation Pedals - TWM Short Shifter + M1 Abrams Knob - 05+ Center Console
#9 boxpin
boxpin
  • 835 posts
Posted 31 January 2012 - 06:23 PM
I am smelling another Group Buy.
13.7 @ 99 Automagic Posted Image 13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#10 Serge
Serge
  • 10,667 posts
Posted 31 January 2012 - 08:41 PM
http://www.aliexpres.../103525522.html
It's a bit pricy at $58 shipped for a pair of bulbs, but I chose to do it just because you get a better beam pattern. And yes, there are manufacturers that use the labels H3 and H3C interchangeably, so it becomes difficult trying to find them.
Here's a tid bit: I was looking to buy ~100+ units of these and for H3 bulbs my cost would be $1/each, for H3C bulbs, the cost would be $15/each (if not more).
Serge - 95 850 T5
#11 TaskMule
TaskMule
  • 1,151 posts
Posted 31 January 2012 - 11:15 PM
I wonder if John (sharpHID) can get them? Either way, I'd be down if they were 30$ a set on a GB.
98 V70R AWD
97 855R
#12 gmsgltr
gmsgltr
  • 3,654 posts
Posted 31 January 2012 - 11:31 PM
Also down for a group buy...
#13 Serge
Serge
  • 10,667 posts
Posted 31 January 2012 - 11:43 PM
His come from DDM tuning, who get them from the suppliers I work with. Otherwise he gets them from the same suppliers.
Serge - 95 850 T5
#14 swedishiron
swedishiron
  • 367 posts
Posted 01 February 2012 - 12:17 AM
I am looking into putting these into my S60R for FOGS, I have read good reviews from people who have installed them, reviews have stated the quality is better than cheaper chinese off brand hid conversion kits:
http://www.carid.com...kit-344369.html
#15 swedishiron
swedishiron
  • 367 posts
Posted 01 February 2012 - 12:50 AM
The brand carid is carrying is called Notto SE
#16 Serge
Serge
  • 10,667 posts
Posted 01 February 2012 - 01:04 AM
Going to give you a heads up on HID kits: They are all virtually the same. Just find a retailer that gives you warranty.
Serge - 95 850 T5
#17 Kevin.
    Dick Dabber
  • 5,447 posts
  • Interests:United States Air Force
Posted 01 February 2012 - 01:17 AM
Check these out if you want to actually increase your light output
http://www.theretrof...products_id=249
I'm getting these fairly soon for my car
95 850 GLT | Tropic Green Metallic | 219k | ARD Tune | M56H | E-Code Conversion | Full LED interior
2W131L - USAF
#18 TaskMule
TaskMule
  • 1,151 posts
Posted 02 February 2012 - 12:23 AM
I'm suspect of aftermarket lamps of this sort. They look flimsy. I bought some Hella MicroDE's on the Hella rep, and recommendation of a few members here, and they literally disintegrated after only one winter here. Cheaply made junk, with poor materials, and not anywhere near the Volvo build standard.
I ended up buying a good used set of 850 original's, and with a kit from SharpHID, it's an excellent set-up.
Once again, OEM proves the winner.
98 V70R AWD
97 855R
#19 TaskMule
TaskMule
  • 1,151 posts
Posted 02 February 2012 - 12:30 AM
SharpHID.com is John Sharp, a member here. You won't find one person on here who has had an issue with any of the top quality gear he sells. Lifetime warranty too. Why take a chance on anyone else?
98 V70R AWD
97 855R
#20 Serge
Serge
  • 10,667 posts
Posted 02 February 2012 - 01:20 AM
OEM is definitely the best, however, TheRetrofitSource.com is excellent. Matt, the owner, is a very stand up guy with excellent customer service. Him and I have done wholesale business some months back and he's a very good person to deal with.
Serge - 95 850 T5
