Trans Shopping For My T5, Need Some Clarification.
Posted 30 January 2012 - 03:43 PM
Will any 850 trans work, N/A or T5?
What about newer ones like from a 98 N/A s70?
IF N/A autos are an option, would they make better donors as they may have had an easier life?
I heard that the newer ones have different ratios, and also that T5 autos are built stronger then NAs. But this is just what i have been told.
I know newer ones do not have the speed sensor in them, but it is possible to tap the ABS sensor to fill in for the job.
If anyone could clear this up for me i would be very appreciative.
Thanks!
Posted 30 January 2012 - 07:17 PM
i found one with 118,000 miles for $300. I would recommend due diligence and spend $50 for Carfax reports on the VIN #s on the transmissions. That way, you can make sure to find one that was written off in an accident, not brought in as junk. I also ruled out any from super-hot climates, like one from Arizona. Heat is NOT an A/T's friend.
So far, knock on wood, I seem to have gotten a winner.
Posted 30 January 2012 - 07:42 PM
Posted 03 February 2012 - 10:26 PM
Also doesn't have to be from a T5, it can be from any turbo.
Ohh and the torque converter has a different stall RPM from N/A to turbo I beleive.
Posted 03 February 2012 - 11:07 PM
Posted 03 February 2012 - 11:21 PM
Also the TCU for the N/A has set points for TC lock-up to be at like 30-40mph and then at 50mph.
The turbo has TC lock-up above 50mph only. Its only te TCU that does this, no mechanical difference internally for lock-up speeds.
Posted 04 February 2012 - 01:18 AM
Gear ratios are the same, final drive is different, 2.74:1 NA vs 2.54:1 Turbo. Can't find the stall speeds, but the TC part numbers are different.
Posted 04 February 2012 - 04:14 AM
Posted 04 February 2012 - 04:55 AM
SHIFT SPEED SPECIFICATIONS
SHIFT SPEED SPECIFICATIONS (2.3L TURBO) (1)
Application MPH
Economy Mode
1st-2nd ............................................. 25
2nd-3rd ............................................. 51
3rd-4th ............................................. 76
4th-3rd ............................................. 53
3rd-2nd ............................................. 31
2nd-1st ............................................. 16
Sport Mode
1st-2nd ............................................. 36
2nd-3rd ............................................. 69
3rd-4th ............................................ 106
4th-3rd ............................................. 62
3rd-2nd ............................................. 47
2nd-1st ............................................. 26
(1) - With shift lever in "D" position and throttle valve
open 60 percent.
SHIFT SPEED SPECIFICATIONS (2.4L NON-TURBO) (1)
Application MPH
Economy Mode
1st-2nd ............................................. 24
2nd-3rd ............................................. 48
3rd-4th ............................................. 75
4th-3rd ............................................. 60
3rd-2nd ............................................. 36
2nd-1st ............................................. 15
Sport Mode
1st-2nd ............................................. 35
2nd-3rd ............................................. 68
3rd-4th ............................................ 101
4th-3rd ............................................. 86
3rd-2nd ............................................. 57
2nd-1st ............................................. 24
open 60 percent.
LOCK-UP SPEED SPECIFICATIONS
LOCK-UP SPEED SPECIFICATIONS (2.3L TURBO) (1) (2) (3)
Application MPH
Economy & Sport Mode
Lock-Up ON - 4th Gear .............................. 129
Lock-Up OFF - 4th Gear ............................. 124
LOCK-UP SPEED SPECIFICATIONS (2.4L NON-TURBO) (1) (2)
Application MPH
Economy Mode
Lock-Up ON
2nd Gear .......................................... 25
3rd Gear .......................................... 49
4th Gear .......................................... 73
Lock-Up OFF
2nd Gear .......................................... 23
3rd Gear .......................................... 44
4th Gear .......................................... 68
Sport Mode
Lock-Up ON
2nd Gear .......................................... 35
3rd Gear .......................................... 65
4th Gear .......................................... 96
Lock-Up OFF
2nd Gear .......................................... 33
3rd Gear .......................................... 60
4th Gear .......................................... 90
Edited by survolvo, 04 February 2012 - 04:56 AM.
1996 854T x2
Posted 04 February 2012 - 11:22 PM
I am in silsbee tx, 77656. Shipping would probably be around $125.00
You can contact me at Thunderbirdsc@gmail.com or 409-782-3451
Posted 04 February 2012 - 11:42 PM
Thanks for the offer, i will keep you in mind if i cant find anything locally, 105k isnt to bad either.
My other Q was weather a 96+ will bolt right up other then the speedo mod?
Posted 04 February 2012 - 11:47 PM
When i said TCU i mean the TCU Harness plug that goes on top of the tranny.
#14
Posted 04 February 2012 - 11:52 PM
Hmm. Isnt there a speed sensor on the output shaft that had to be re wired to the ABS? from what i kinda remeber it was its own pair of wires seperate from the main TCU harness. I thought the TCU needed to know the speed so it could shift right, or does it have its own signal from some where?
#15
Posted 05 February 2012 - 03:24 AM
98 S70 GLT-M * 79 242 GT * 96 850R * 84 F150 * 99 S70 AWD
72 Chevrolet K10 Cheyenne*78 242 GT*98 S70 T5*00 V70R*04 V70R*96 855R *97 855R*98 V70R*98 V70R*99 V70R*99 V70R*98 V70 NA*98 V70 XC
#17
Posted 06 February 2012 - 02:04 PM
#19
Posted 06 February 2012 - 02:44 PM
Application MPH
Application MPH
Economy Mode
Lock-Up ON
Lock-Up OFF
Sport Mode
Lock-Up ON
Lock-Up OFF
Is that saying the turbo TC just never locks up below 129mph?
