Trans Shopping For My T5, Need Some Clarification.
850 855 t5 turbo transmisison
21 replies to this topic
#1 vivalavolvo
vivalavolvo
  • 183 posts
Posted 30 January 2012 - 03:43 PM
The trans in my 95 855 T5 went boom boom (auto). I have a few questions about the autos that are in different volvos. Locally there aren't to many 850 T5 donors, and im trying to find one with the lowest miles and do an accumulator mod along with a bigger oil cooler.
Will any 850 trans work, N/A or T5?
What about newer ones like from a 98 N/A s70?
IF N/A autos are an option, would they make better donors as they may have had an easier life?
I heard that the newer ones have different ratios, and also that T5 autos are built stronger then NAs. But this is just what i have been told.
I know newer ones do not have the speed sensor in them, but it is possible to tap the ABS sensor to fill in for the job.
If anyone could clear this up for me i would be very appreciative.
Thanks!
1978 242DL - 1995 855 T5 ARD Green - 1991 Stanza XE
#2 BlackBrick
BlackBrick
  • 706 posts
Posted 30 January 2012 - 07:17 PM
i'm not an expert, but i was shopping for a used A/T last month, and it seemed like they were all the exact same (I have a 97, and was only looking at 96-97 A/Ts).
i found one with 118,000 miles for $300. I would recommend due diligence and spend $50 for Carfax reports on the VIN #s on the transmissions. That way, you can make sure to find one that was written off in an accident, not brought in as junk. I also ruled out any from super-hot climates, like one from Arizona. Heat is NOT an A/T's friend.
So far, knock on wood, I seem to have gotten a winner.
1997 Volvo 850 GLT wagon - 129K miles
1997 Volvo 850 R sedan - 124K miles
#3 Keaton85
Keaton85
    My zip tie is bigger than yours.
  • 7,574 posts
Posted 30 January 2012 - 07:42 PM
N/A and turbo trannys have different ratios. Can't remember off the top of my head though.
#4 vivalavolvo
vivalavolvo
  • 183 posts
Posted 03 February 2012 - 08:54 PM
Thanks for the tips. I wasn't aware of the ratios difference within the same series.
What about 96+ T5 trans? I seem to be able to find more of those then the 94/95s.
#5 Keaton85
Keaton85
  • 7,574 posts
Posted 03 February 2012 - 10:26 PM
It doesn't mean you can't use an N/A though. I just can't remember what the ratios were but someone that has VADIS going could pull those specs.
Also doesn't have to be from a T5, it can be from any turbo.
Ohh and the torque converter has a different stall RPM from N/A to turbo I beleive.
#6 bergmjs
bergmjs
  • 2,062 posts
Posted 03 February 2012 - 11:07 PM
I thought all 850's got AW50-42LE transmissions which were all the same. The 940 got different transmissions between NA and turbos, but I thought all 850 automatics were the same.
'95 854 T5M 195k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue - DEAD - To be parted out
'04 S60R - 125k
#7 Keaton85
Keaton85
  • 7,574 posts
Posted 03 February 2012 - 11:21 PM
I may be wrong but the ratios an TC stall is different. Shouldn't matter much though.
Also the TCU for the N/A has set points for TC lock-up to be at like 30-40mph and then at 50mph.
The turbo has TC lock-up above 50mph only. Its only te TCU that does this, no mechanical difference internally for lock-up speeds.
#8 Deimos
Deimos
    I beat anal fissures
  • 993 posts
Posted 04 February 2012 - 01:18 AM
The '95 NA had a 1208573 Trans and a 6843110 TC. '95 Turbo had a 1208560 Trans and a 6843635 TC.
Gear ratios are the same, final drive is different, 2.74:1 NA vs 2.54:1 Turbo. Can't find the stall speeds, but the TC part numbers are different.
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
#9 Jardim
Posted 04 February 2012 - 04:14 AM
So if you get an NA transmission, your T5 will accelerate a little faster but cruise a little higher in the RPM range on the highway, I remember my was 3k rpm @ 80 mph so at 80 on this one should be around 3500 rpms
#10 survolvo
survolvo
    Hollywood
  • 3,224 posts
Posted 04 February 2012 - 04:55 AM
FROM HERE
SHIFT SPEED SPECIFICATIONS
SHIFT SPEED SPECIFICATIONS (2.3L TURBO) (1)
Application MPH
Economy Mode
1st-2nd ............................................. 25
2nd-3rd ............................................. 51
3rd-4th ............................................. 76
4th-3rd ............................................. 53
3rd-2nd ............................................. 31
2nd-1st ............................................. 16
Sport Mode
1st-2nd ............................................. 36
2nd-3rd ............................................. 69
3rd-4th ............................................ 106
4th-3rd ............................................. 62
3rd-2nd ............................................. 47
2nd-1st ............................................. 26
(1) - With shift lever in "D" position and throttle valve
open 60 percent.
SHIFT SPEED SPECIFICATIONS (2.4L NON-TURBO) (1)
Application MPH
Economy Mode
1st-2nd ............................................. 24
2nd-3rd ............................................. 48
3rd-4th ............................................. 75
4th-3rd ............................................. 60
3rd-2nd ............................................. 36
2nd-1st ............................................. 15
Sport Mode
1st-2nd ............................................. 35
2nd-3rd ............................................. 68
3rd-4th ............................................ 101
4th-3rd ............................................. 86
3rd-2nd ............................................. 57
2nd-1st ............................................. 24
open 60 percent.
LOCK-UP SPEED SPECIFICATIONS
LOCK-UP SPEED SPECIFICATIONS (2.3L TURBO) (1) (2) (3)
Application MPH
Economy & Sport Mode
Lock-Up ON - 4th Gear .............................. 129
Lock-Up OFF - 4th Gear ............................. 124
LOCK-UP SPEED SPECIFICATIONS (2.4L NON-TURBO) (1) (2)
Application MPH
Economy Mode
Lock-Up ON
2nd Gear .......................................... 25
3rd Gear .......................................... 49
4th Gear .......................................... 73
Lock-Up OFF
2nd Gear .......................................... 23
3rd Gear .......................................... 44
4th Gear .......................................... 68
Sport Mode
Lock-Up ON
2nd Gear .......................................... 35
3rd Gear .......................................... 65
4th Gear .......................................... 96
Lock-Up OFF
2nd Gear .......................................... 33
3rd Gear .......................................... 60
4th Gear .......................................... 90
Edited by survolvo, 04 February 2012 - 04:56 AM.
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, ARD Billet 16t , Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo OEM Strut Tower Brace, Konis, IPD/TME springs, ARD Green Tune
#11 thunderbirdsc
thunderbirdsc
  • 81 posts
Posted 04 February 2012 - 11:22 PM
I recently swapped to manual and have the auto from the 1998 t5 that I would sell for $200.00, it has 105,000 miles on it.
I am in silsbee tx, 77656. Shipping would probably be around $125.00
You can contact me at Thunderbirdsc@gmail.com or 409-782-3451
#12 vivalavolvo
vivalavolvo
  • 183 posts
Posted 04 February 2012 - 11:42 PM
Thanks for the offer, i will keep you in mind if i cant find anything locally, 105k isnt to bad either.
My other Q was weather a 96+ will bolt right up other then the speedo mod?
#13 Jardim
Posted 04 February 2012 - 11:47 PM
Yes, but in order to have a speedo you are going to have to locate the speed sensor wires in your TCU plug and splice them into your ABS....something like that i need to do it too. Been using GPS so the speedo isnt really something im worried about.
When i said TCU i mean the TCU Harness plug that goes on top of the tranny.
#14 vivalavolvo
vivalavolvo
  • 183 posts
Posted 04 February 2012 - 11:52 PM
Hmm. Isnt there a speed sensor on the output shaft that had to be re wired to the ABS? from what i kinda remeber it was its own pair of wires seperate from the main TCU harness. I thought the TCU needed to know the speed so it could shift right, or does it have its own signal from some where?
#15 volvoskiah
volvoskiah
  • 1,752 posts
Posted 05 February 2012 - 03:24 AM
I have one out of a 98 t5, shifted fine. 197k miles, yours for free if you come take it out of my garage.
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
#16 vivalavolvo
vivalavolvo
  • 183 posts
Posted 05 February 2012 - 06:40 AM
That means driving through jersey :(
#17 volvoskiah
volvoskiah
  • 1,752 posts
Posted 06 February 2012 - 02:04 PM
Haha jersey is a great place!
#18 vivalavolvo
vivalavolvo
  • 183 posts
Posted 06 February 2012 - 02:39 PM
lol bad things always happen to me when i cross that bridge
#19 bergmjs
bergmjs
  • 2,062 posts
Posted 06 February 2012 - 02:44 PM
Application MPH
Application MPH
Economy Mode
Lock-Up ON
Lock-Up OFF
Sport Mode
Lock-Up ON
Lock-Up OFF
Is that saying the turbo TC just never locks up below 129mph?
'04 S60R - 125k
#20 vivalavolvo
vivalavolvo
  • 183 posts
Posted 06 February 2012 - 04:10 PM
@ 60% throttle
