25Mm Rear Anti Sway Bar Teamed Up With Stock Front On 850R Autocross Setup.
Posted 31 January 2012 - 12:37 AM
Posted 31 January 2012 - 12:45 AM
for specifics, im no autocrosser... but i did the rear 25mm first with the stock 855r front and wasnt too impressed, i could feel the rear having less flex than the front and this is even more feasible on a wagon imo. then i put the front in a month later and that is where i noticed the biggest difference and not just with performance, also with going over small bumps etc. alongisde my sways i have tki endlinks and ipd blue springs and koni yellows all around
my car was twitchier with both 25's to answer that question
hope more experienced guys post here for ya as well...
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
Posted 31 January 2012 - 12:52 AM
VolvoRacer850R, on 31 January 2012 - 12:37 AM, said:
That setup will work better for you in autocross. I assume you are not running an LSD, so the smaller bar in the front will help with traction in the corners. The rear will rotate better and you should feel the difference in turns.
I run 25/28, but I am manual swapped with LSD, so traction isn't an issue in a corner.
Posted 31 January 2012 - 12:53 AM
Posted 31 January 2012 - 12:56 AM
Posted 31 January 2012 - 12:58 AM
Posted 31 January 2012 - 01:00 AM
dublin14, on 31 January 2012 - 12:56 AM, said:
Posted 31 January 2012 - 01:02 AM
ipd sparkplug wires, HD TCV, CBV, sways and springs, K&N filter
1999 Jeep Grand Cherokee Laredo, unstopable
Posted 31 January 2012 - 01:14 AM
Zappo, on 31 January 2012 - 01:00 AM, said:
For sure.. that makes sense for autocrossing. I tried autocrossing a few times with FWD but much prefer road courses.
gdizzle, on 31 January 2012 - 12:58 AM, said:
Only when your girl askes me.
Edited by dublin14, 31 January 2012 - 01:13 AM.
Posted 31 January 2012 - 01:38 AM
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
Posted 31 January 2012 - 03:02 AM
Chris / 96 850 R-M / 98 S70 GLT -T5
Posted 31 January 2012 - 03:30 AM
to add some firmness and ajustability but for now its looking like the Sachs. Any more info you guys can provide would be great. So far this has helped a ton. I'm going to probably end up heading in this direction.
#14
Posted 31 January 2012 - 04:00 AM
#15
Posted 31 January 2012 - 04:34 AM
It isn't that big of a deal. In fact, if you could find one you might actually like the 28mm rear if the course is that tight, but they are rare.
Coilovers tend to even things out so running a stock front with 28mm rear with coilovers is not the same as without. Danny ran that setup a few years ago on his S70.
Save up for the LSD.
#16
Posted 31 January 2012 - 04:25 PM
Would rear 25mm sway with stock front make it feel better and more stable, or should I do sways both front and rear?
#17
Posted 31 January 2012 - 04:51 PM
I HATE THIS CAR...
INSIDE WHEEL SPIN!
I HATE THIS CAR...
I HATE THIS CAR....
GOD PLEASE WHY AM I DOING THIS I NEED TO RETHINK MY LIFE CHOICES
MORE INSIDE WHEEL SPIN
I HATE AUTOCROSS
I HATE AUTOCROSS
FUCK IT IM ENDING MY LIFE
Mesoam, on 24 June 2009 - 02:33 AM, said:
#18
Posted 31 January 2012 - 06:45 PM
Fishey, on 31 January 2012 - 04:51 PM, said:
As usual, Fishy is no help at all.
_HighVoltage_, on 31 January 2012 - 04:25 PM, said:
#19
Posted 31 January 2012 - 07:05 PM
Runnin 25 rear, stock front. Car is pretty well balanced, if you turn proper you won't have much plowing. I am however running KW var 2's though, so that changes things. I also run 215/40 on 8" wide rims for the added stiffness on the sidewall.
#20
Posted 31 January 2012 - 10:54 PM
I HATE THIS CAR...
INSIDE WHEEL SPIN!
I HATE THIS CAR...
I HATE THIS CAR....
I HATE AUTOCROSS
I HATE AUTOCROSS
monkey IT IM ENDING MY LIFE
It actually held up pretty well, consider this a pontiac 6.0 GTO ran a 59.5 I ran a 59.9 . Best time was a corvette on slicks with a driving instructor which ran a 54.7. Its not a terrible car it'snot perfect but its fun. Until i can buy a real race car i'm doing best i can with what i have. One day maybe.... lots of liquor stor robberies for that to happen.
thanks Zappo for the help. any other car setup or autocross advice you have keep it coming . Aside from LSD and slicks. Anyplace good to buy used tires? Know anyone who might have a sway bar for sale? If i can get a deal i'm all about it. IPD quoted me $235 for just the rear bar. thanks guys you have been very helpful.
