Adjusting Wastegate Questions
13 replies to this topic
#1 FAST850R
FAST850R
  • 563 posts
Posted 31 January 2012 - 11:07 PM
Hello,
I have a stock 1996 850R and I read an article about adjusting wastegate.
I checked mine and I actually had to lossen up the nut...shouldn't I tighten it up to get more response from the turbo?
Everything is bone stock, nothing modified, nothing touched....
I could pull the wastegate actuator arm by force to make it tighter....is it correct way to do it?
Please confirm how to do this in correct way.
Thank you.
I loosend it up by 2~3 turns to fit the arm into c-clip. No tension between the c-clip and the wastegate.
I drove my car but I didn't feel any changes.
Thanks.
#2 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 31 January 2012 - 11:17 PM
you want to shorten the arm by a few turns at a time. try 3-4 and see how it drives. As the arm will be shorter, you will have tension on the wastegate when you reconnect the arm
1996 855R
#3 scumcity14
scumcity14
  • 2,658 posts
Posted 31 January 2012 - 11:24 PM
Actuator needs to be pressurized before actuator arm is placed on wastegate. If you did this with out proper PSI on the actuator your wastegate isn't properly adjusted. This IPD video covers it..start @ 5:00 in for your car. There is chart at the end for PSI settings..you don't need their tool, just a handheld vac. pump that will do pressure as well
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
#4 FAST850R
FAST850R
  • 563 posts
Posted 31 January 2012 - 11:25 PM
Thank you very much for the reply.
I wanted to make sure whether it's ok to have tension on the wastegate.
I'll adjust it now and post here!
#5 FAST850R
FAST850R
  • 563 posts
Posted 01 February 2012 - 12:24 AM
Thank you for the link.
I adjusted it without the vac pump.
So 850r engine factory psi is 1.8, which is around 100mmHG, correct?
After I properly adjust it, I can 2turns to tighten it for more reponsness, correct?
#6 bergmjs
bergmjs
  • 1,923 posts
Posted 01 February 2012 - 06:16 AM
This makes no sense. Pressure and vacuum are two different units.
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
#7 Jardim
  • 1,276 posts
  • Interests:Being a Volvo Rat. Eating, drinking water, sleeping, working, etc.
Posted 01 February 2012 - 06:37 AM
Not only different units, but two different forces lol.
94 854 T5M----------------Volvo Rat
#8 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
  • Gender:Not Telling
Posted 01 February 2012 - 06:46 AM
just shorten it by 2 full turns, should be safe enough and quicker spool.
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
#9 FAST850R
FAST850R
  • 563 posts
Posted 01 February 2012 - 03:25 PM
Oops, I thought I could convert psi to mmHG.
I guess I need to buy a tool... Any suggestion?
Thank you
#10 FAST850R
FAST850R
  • 563 posts
Posted 01 February 2012 - 04:01 PM
Never mind. I searched and found an answer.
#11 jschaefer7406
jschaefer7406
  • 487 posts
Posted 02 February 2012 - 11:59 PM
Makes perfect sense. He was right, 1.81 psi is roughly 931 mm/Hg. I found this when using the Wife's blood pressure cuff to set my actuator ;)...
Hope this helps,
Joe
#12 FAST850R
FAST850R
  • 563 posts
Posted 07 February 2012 - 03:31 AM
Hope this helps,
Joe
Thank you for the reply.
I guess I am right then :)
#13 MarkoC70T5
MarkoC70T5
  • 77 posts
  • Interests:Volvo, Model scale trucks, Racing
Posted 07 February 2012 - 12:45 PM
Just a question i see that you stock need 1.81 PSI but what the value for a 19T that runs on 1.35bar.
And how do you setup a custom turbo like a Garret. Are there any stock value's or is it al related to the Pressure the turbo runs on?
C70T5 Engine: 19T/Green injectors/BMC airfilter/3inch DP/2.5inch exhaust/Walbro pump//MTE custom software @ 1.37bar /Larger intercooler
#14 T5wagon1717
T5wagon1717
    Best way to commit insurance fraud is with a hammer.
  • 822 posts
Posted 09 February 2012 - 03:17 AM
You can tighten it a little, play around with it a little, but be careful, you can get very quick spool. Might want to get a mbc - you'll see more gain and also get quicker spool. But for a quick in the garage, adjustments adjust it to there the arm goes onto the clip with no play. Thats around the stock setting (on my car and a couple others it was, but some cars are different) and you could tighten it a little from there. Maybe a couple turns, but go up gradually. Have fun....get a boost gauge.
1997 855 T5. 16T, japanifold, ipd turboback, ipd stage 1, Hallman pro rx (17psi), ipd intake, Sconeman intake pipe, fremax brakes, 18" vectors/16" mimas, B&M tranny cooler, tinted angel eyes,10000K hids, tint, rallitek boost gauge, greddy turbo timer, sirius sportster 5 + ipod hookup, Valentine 1 Radar.....
