Aem Wideband Connector
9 replies to this topic
#1 T5Hammy
T5Hammy
  • 324 posts
  • Interests:Long walks on the beach
Posted 01 February 2012 - 09:14 PM
So recently the ziptie holding my wideband connector (6-pin connector from bosch 4.2 sensor to the wire harness) broke, leaving the connector to drag on the ground and get destroyed.
My question is does anyone know where to buy one of the connectors only, or if not can I hard wire the sensor to the harness (not sure if its just a 6-pin connector or if there is any kind of required circutry in it). AEM doesn't appear to provide them, here is the gauge/sensor setup I'm running: http://www.aemelectr...-fuel-gauge-25/
Any help is appreciated, Thanks
1998 s70 t5- auto :(, Stage 0, kw var 3, Ipd short ram, N/A TB from Snabb, FMIC 29x9x3, OBX exhaust, 18" Ipd pegs flat black, black projectors, aux tranny cooler.
#2 s_moneh
s_moneh
  • 1,166 posts
Posted 01 February 2012 - 11:13 PM
i'm on the same boat, due to testing and what not i took need that same wiire, i've been looking aswell to no avail so i'll be sub'd here
#3 gmsgltr
gmsgltr
  • 3,654 posts
Posted 02 February 2012 - 02:12 AM
ebay? there are always parts of the aem uego on there
- Greg - 96 Red/Tan 855 R 96k miles -
FOR SALE: Used 75k Miles OEM 16T Turbo/Angled/Ipd HD CBV - PM ME
#4 mojojo
mojojo
  • 353 posts
Posted 02 February 2012 - 04:29 AM
It doesn't look like there's any more to it. Can you disassemble the connector?
Can either of you post a close, detailed, clear picture of the connector you need?
If yes, get me these angles:
1-side shot
2-center shot, showing male and female pins
If you can get me these pictures, I may be able to get you a replacement connector. Worst case scenario, remove the connector and use a deustch connector. I could get both of you these connectors (1 male, 1 female).
#5 mojojo
mojojo
  • 353 posts
Posted 02 February 2012 - 04:42 AM
Did some quick searching here, definitely looks like there's more to it than a typical connector. There appears to be some tabs that you should be able to release and start to disassemble the connector. When you can take it apart, let us know what you find.
#6 s_moneh
s_moneh
  • 1,166 posts
Posted 02 February 2012 - 06:14 AM
gmsgltr, he is right
this one seems to be what i personally need..
as for op not too sure
http://www.ebay.com/...967324552597584
#7 T5Hammy
T5Hammy
  • 324 posts
Posted 02 February 2012 - 08:04 AM
I will pull it apart and see whats inside for future reference.
Yup that looks like it, didn't know the uego had the same connector. I'll need that and the sensor though if I take my old one apart and it looks too complex for me to jury-rig.
Thanks guys!
#8 s_moneh
s_moneh
  • 1,166 posts
Posted 02 February 2012 - 08:32 PM
they sell the o2 sensor seperatly on ebay aswell
#9 mojojo
mojojo
  • 353 posts
Posted 04 February 2012 - 04:47 AM
Thanks guys!
Take pictures, and post here. I may be able to find you a perfectly fine/functioning/safe work around for spending more money... but it is your call.
#10 T5Hammy
T5Hammy
  • 324 posts
Posted 04 February 2012 - 05:40 AM
Definitely, I should get a chance to get some pics this weekend
