Vac Nipple On Intake Pipe, Where Does It Go?
volvo 850 vacuum hose intake pipe silicone
13 replies to this topic
#1 Tommy.
Tommy.
  • 4,098 posts
Posted 02 February 2012 - 12:16 AM
I am putting in a custom intake pipe and I found a vac nipple that was completely uncovered on the underside of the pipe closest to the airbox. It is the bottom one in this picture.
The top nipple goes into my BCS... and the bottom one was uncovered when I removed the pipe. Is there a line supposed to be there and if yes, where the heck does it go?
Thanks!
1997 855R Black on Black, Bilstein HD's, IPD Blues, TITANS, 3" Custom Exhaust, Custom intake pipe
("insert funny quote here")
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 02 February 2012 - 12:20 AM
To the evap system running along the back side of the motor on the coolent pipe.
#3 Oreo931
    Level 8 Senior Member
  • 23,659 posts
Posted 02 February 2012 - 01:39 AM
If that hose was replaced, the new ones come with an additional nipple so they can fit on several models. When I replaced mine I just capped the extra nipple off. That looks like the newer version.
#4 Tommy.
Tommy.
  • 4,098 posts
Posted 02 February 2012 - 01:45 AM
Okay thanks. Still don't see it/how it runs but no worries.
I'm just gonna not drill out a hole for it in the mandrel pipe I'm making.
#5 Hanks
Hanks
  • 3,374 posts
Posted 02 February 2012 - 02:03 AM
i didnt think there was evap on the HPT 850's? only the lpt
#6 Keaton85
Keaton85
  • 6,439 posts
Posted 02 February 2012 - 03:51 AM
No evap?!?
#7 Tommy.
Tommy.
  • 4,098 posts
Posted 02 February 2012 - 05:44 AM
Hmmm I would be interested to know too... I just ended up not drilling a hole and if I run into issues I will just drill one later.
#8 scumcity14
scumcity14
  • 2,658 posts
Posted 02 February 2012 - 12:53 PM
View Postplease delete, on 02 February 2012 - 03:51 AM, said:
No evap?!?
Yeah I think Evap has been madatory since the early 80s on all cars sold in the US...
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
#9 Hanks
Hanks
  • 3,374 posts
Posted 02 February 2012 - 04:21 PM
maybe im thinking of SAS.
edit ya, forgot about the charcoal canister :P
Edited by Hanks, 02 February 2012 - 04:25 PM.
#10 Tommy.
Tommy.
  • 4,098 posts
Posted 02 February 2012 - 05:51 PM
Maybe the EGR too. I got those confused one time.
#11 bunce1260
bunce1260
  • 48 posts
Posted 02 February 2012 - 09:40 PM
Isnt it listed as the fresh air vac hose on the under hood diagram?
1995 Volvo 850 Turbo wagon
#12 Tommy.
Tommy.
  • 4,098 posts
Posted 02 February 2012 - 11:40 PM
I just didn't drill a hole for the brass fitting and it seems to be running fine. we will see. Thanks for the help everyone :tup: +1 for everyone.
#13 Smiles855R
Smiles855R
  • 14 posts
Posted 04 February 2012 - 03:19 AM
It is the fresh air vac line. The Blue line plugs in to that nipple, thats how mine is set up.
Attached File  vacuum-hose-diagram-850.jpg   137.98K   21 downloads
Attached File  problem.jpg   161.51K   23 downloads
1996 855R - White, Charcoal Interior, IPD short ram intake, IPD MSD Ignition coil, silicone vacuum lines, OEM radiator hoses, IPD sway bars 25/22, IPD HD end links, stock everything else
#14 TyConn
TyConn
    Delta Bravo
  • 900 posts
  • Interests:Wings 'n Things
Posted 05 February 2012 - 07:01 PM
so that other line goes to the shut off valve?
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
Also tagged with volvo, 850, vacuum, hose, intake, pipe, silicone
